General AML S802 Device release discussions
    Javimetal, any chance Beelink release kernel source code with proper customer files? They should be GPL complaint I guess.... And usually, the generic amlogic kernel source is not enough
      FWIW
      For anyone who is after a square, rather than round box, the enybox EM8 I ordered should arrive any day now, so I will review and compare with the results the kind chaps have already provided on here.
      Will be interesting to see if I can sucessfully flash the tronsmart/beelink firmware to it.
        Originally posted by geekbuying View Post
        The tronsmart vega S89 is not used the S802-H, it is S802, but it use XBMC to do the software decoding. so you still can get DTS and dolby via XBMC. and about passthrough test, check here
        i have heared tronsmart will release a new model of S89 which use the S802-H.
        the only difference should be s802-h chip will support hardware decoding dolby/dts video. while S802 just can do via software decoding.
        Eric
        This^^^^
        Oh and it seems that different XBMC releases cause the sound issue on HDMI so it might be an XBMC issue.... might be...
          Looking forward to your review.
            Hello all! The version of XBMC wich comes with the Tronsmart vega S89 doesnt come with the XBMC 14 alpha? If so it could be because of the alpha version! If i am right does it has better performance with the XBMC 12?
              12 will not have hardware decoding. 13 (Gotham) is in beta right now and should work great. 14 is non-existent they just renamed it from 13-betaX to 14
              Sent from my mobile device. Please excuse any typos.
              Only after you've donated to Finless and Neomode are you allowed to donate here.
                Originally posted by noderat View Post
                12 will not have hardware encoding. 13 (Gotham) is in beta right now and should work great. 14 is non-existent they just renamed it from 13-betaX to 14
                The problems people are having could be because the version of xbmc no??
                If thats the case, uninstalling the version that comes with Vega S89 and installing the lastest beta could resolve most problems??
                If so it could be a fix... i wonder.
                P.S... Waiting for mine ti arrive which could be in 15 working days to a month :| but following the thread and news closely.
                  Re: EM8 Amlogic S802 quad core 2Ghz + Octa core Mali 450: FIRST PRICE INFO!
                  I think it is the Gotham beta that comes installed on it.
                  Sent from my Nexus 5 using Tapatalk
                    no ethernet
                    I just received mine. But ethernet does not work. Plugged the ethernet cable, no connection. Is there any solution to this ?
                    Mine is the Tronsmart 8GB version.
                    Using a Tronsmart Vega Elite S89.
                      I just received mine. Testing now. Can confirm it the play store paid app bug. Likely due to lack of secure storage area on internal memory.
                        I guess its fairly easy to make a secure internal storage partition?
                          No clue, honestly. I haven't really played with android internals since my G1, so I'm waaay behind.
                            I cant test paid apps because I have never bought one!
                            I cant believe it is secure storage. It must be some bug.
                            You guys will have to tell me if my ROM fixes it as I did make some play store tweaks.
                              I have a multitude of paid apps I use such as external keyboard helper that I use regularly. I'd be happy to test and let you know.
                                Happy to help.
