General AML S802 Device release discussions
    Originally posted by reddragon72 View Post
    So I looked up the LG Optimus G on Antutu and this is what the official benchmarks are...
    enchmarks on AnTuTu Benchmark 3.x versions
    SCORE CPU-I CPU-F MEM 2D 3D DB SD-READ SD_WRITE
    19078 4499 3517 3149 1306 5697 545 216 149
    So this is hitting 30K
    Can you post up all the scores like above so we can compare everything. If the S802 is doing better than the S4Pro then I'll move back to this now that you say HDMI/SPDIF is working fine with AC3/DTS
    Model: Beelink M8
    AnTuTu Benchmark 4.3.3
    Score: 29202
    UX: Android 4.4.2
    Multitask: 5238
    Runtime: 2008
    CPU: 1992 Mhz(x4)
    CPU integer: 3451
    CPU float-point: 2479
    RAM: 1258.0/1578.8 MB
    RAM Operation: 2483
    RAM Speed: 1539
    GPU: Mali-450 MP
    2D graphics: [405x720] 1645
    3D graphics: [405x720] 8353
    IO 13356.5/13919.9 MB
    Storage I/O: 1326
    Database I/O: 680
    Android TV Box direct from China. English & Español
      They say in Stock and I ordered a JXD 7800B gaming tab that has not yet shipped.
      Sent from my SAMSUNG-SM-N900A using Tapatalk
        Well, I think no any company in China can ship these days. Shipping companies also stop working. I'm not sure if they back work tomorrow monday or tuesday.
          Originally posted by Javimetal View Post
          Model: Beelink M8
          Score: 29202
          UX: Android 4.4.2
          Multitask: 5238
          Runtime: 2008
          CPU: 1992 Mhz(x4)
          CPU integer: 3451
          RAM Operation: 2483
          RAM Speed: 1539
          GPU: Mali-450 MP
          Storage I/O: 1326
          Database I/O: 680
          So other than the read speed for the internal storage it looks better than the Fire TV.
          Also I am very curious if Android TV is going to be an add on and it can be added to any of these. If so then this is my pick! Amazon's Fire TV is very enticing but my mx1 hasn't failed me so I dought I'll be unhappy with this.
            I will be buying S802 box when more feedbacks are available. Hope the Minix box with S802-H (DD) will available soon.
            I just saw some intresting information about a RK3288 android tv box G20 that has ""Wii" remotes and motion camera.
              It seems that depending on which Benchmark version of Antutu you are using, the subcategories and weighting differ. Maybe a better comparison is the score for the LG G2 run on Antutu 4.3.3, which had a total score a bit more than the Beelink M8:
              LG LG-D802
              Score:30152
              Posted: 2013-12-13 , by AnTuTu
              Benchmarks on AnTuTu Benchmark 4.x versions
              SCORE CPU-I CPU-F MEM 2D 3D DB MEM_PER RAM MULTITASK RenderScript Dalvik
              30152 2748 2774 1149 1551 8531 625 1363 2332 5608 0 3471
              Model: Beelink M8
              Score: 29202
              UX: Android 4.4.2
              Multitask: 5238
              Runtime: 2008
              CPU: 1992 Mhz(x4)
              CPU integer: 3451
              RAM Operation: 2483
              RAM Speed: 1539
              GPU: Mali-450 MP
              Storage I/O: 1326
              Database I/O: 680
                http://www.1pad.cn/43379/
                Be careful about that "G20", after some days we will know the real SoC (still not confirmed). If they did it will be a little dangerous to buy something like this so early.
                  LG LG-D802
                  Score:30152
                  Sometimes I think Benchmarks was made for Marketing
                  User experience is the best test...
                    Quite true. Much like the megapixel wars with cameras. With Antutu, manufacturers (sometimes overtly!) try cheating it like this link about the Asian model variant of the HTC One (M8):
                      Beelink M8 Review
                      Media Player:
                      Video 1080p – Dolby Digital 5.1 HDMI passthrough -> OK
                      Video 1080p – Dolby Digital 5.1 SPDIF passthrough -> OK (without noise)
                      Video 1080p - DTS 5.1 HDMI passthrough -> OK
                      Video 1080p - DTS 5.1 HDMI passthrough -> OK (without noise)
                      Dolby True-HD 5.1 will be tested next week
                      OS: Android 4.4.2 KitKat (Not rooted)
                      this device also have noise when you choose spdif passthrough, just tested, you should choose" enable passthrough" in XBMC, and then you will find the problem.
                      HDMI passthrough has no such problem.
                      Looking for developers
                        As said some posts ago... more tests tomorrow
                          XBMC 14.0 ?? Is this a joke?
                            You don't need to compare the Tronsmart with the Beelink, both are EXACTLY SAME BOARD (and also the new Measy). Just different name on the case.
                            Thanks! Which one is best to buy though? (In terms of firmware updates, etc...)
                            Does the Beelink box come with a remote control?
                              I can report problems to the factory directly, but it will depends on them.
                                Awesome thank you. Just noticed the 16GB Tronsmart on geekbuying has now a remote as well.
                                Very tempted to buy one, but might wait for the next batch. I've seen the tests, apart from the noise on the optical Output, what's wrong with the first batch, if there's no overheat problem?
