Verstuurd vanaf mijn GT-I9105P met Tapatalk
HardwareGuru Rom 04 - Firmware for Neo X7
Re: HardwareGuru Rom 04 - Firmware for Neo X7
Originally posted by HardwareGuru View Posti wil look at the sound patch when i get home.. maybe i forgot to put it in... :S
Originally posted by HardwareGuru View PostSet audio offset 0.200 ms forward in xbmcOriginally posted by Phycopat View PostYes, set Audio offset to +0.250 and all is just fine :-)
Originally posted by silverplated View Postthank you very much!
one more question: as in the 03 version of the rom airplay does not work in 04 too. somebody experiencing the same?
Originally posted by HardwareGuru View PostAntutu gives about 18500 total. I hate benchmark results. They cant be trusted. I seen roms with high scores perform bad and low scores perform good. Just my two cents
Believe me You can trust Antutut 3D score, well atleast You can get the basic view. I have tried many OC's and I have tested the performance on various games and emulators. Best gaming set at the moment: Quickshot V2 720p 1.8ghz/798hz/720hz I get 21385 on Antutu with 3780 3D score, which is the biggest I could get. The actual performance changed alot... Emulators hate 1080p resolution on this device, I play Asphalt 8 on highest settings multiplayer for many hours at stable full fps, which was unable on 1080p at same OC's. Also I can use now force antialiasing (dev settings) all opengl apps support that. I upscale screen to 1080p and still get same results. So basically games look nicer on 720p upscaled to 1080p and antialiasing and perform better.
Originally posted by iANGELgr View PostNo, works but with some problems if you share something from iphone. Its not smooth like Airplay but works ok. Not excellent
i can't get it streaming off my iphone to the x7. the x7 shows up on my iphone as an airplay device. i can even select it but the airplay option resets itself back playback on the iphone. my wifi is fast enough and it works properly with the stock firmware. any suggestions?
Originally posted by Lauris6rape View PostBelieve me You can trust Antutut 3D score, well atleast You can get the basic view. I have tried many OC's and I have tested the performance on various games and emulators. Best gaming set at the moment: Quickshot V2 720p 1.8ghz/798hz/720hz I get 21385 on Antutu with 3780 3D score, which is the biggest I could get. The actual performance changed alot... Emulators hate 1080p resolution on this device, I play Asphalt 8 on highest settings multiplayer for many hours at stable full fps, which was unable on 1080p at same OC's. Also I can use now force antialiasing (dev settings) all opengl apps support that. I upscale screen to 1080p and still get same results. So basically games look nicer on 720p upscaled to 1080p and antialiasing and perform better.
But i think that this rom is made for watching movies mostly, plz correct me If i'm wrong Guru. ;-)
Another thing, scandinavia got an app called Viaplay, that is working in this ROM, no others that i tryed did so, (maybe some live streaming problems with other ROmS?) so once again THANK YOU Guru! :-D i'm alot happier now than before :-D
Originally posted by Phycopat View PostThats also a good setup for _games_ you got there! :-)
I use it for gaming and musicI dont watch movies with apps, If I watch them I do it from USB, mostly BlueRay RIPS
works just good, I am impressed with my TV now
but usual 30 fps crap movies look just like normal TV
I do not know why they made this ROM but this works best at the moment, I have tried them all
I get screen articrap with most of them... But I did not try this one, and I am doing that
I try everything I see
There are currently 2339 users online. 0 members and 2339 guests.
