HardwareGuru Rom 04 - Firmware for Neo X7
    Hope you can help,
    I have your rom running prety stable, no flashing on screen, smooth playback, but the only problem i get is that i only get 16mps on wifi 360 app, any other finless / neo rom i get 56mps on wifi, but your rom gives me the most smooth action.
    Now i have not got a neo x7, mine is a mk809III, is there any way i could boost the wifi mps???
    if i could get that fixed then i have one stable rom
      Originally posted by adfurgerson View Post
      You can't get a diamond by polishing a turd.
      But you can make it shine (ref Mythbusters)
        Originally posted by okey View Post
        Hope you can help,
        Try the 04c beta, i bet that will solve it in your case.
        for ll i know... It does shine
          Minix x7 mini
          So please make one for x7 mini.I love your work,its so great but my x7 died and i have just my x7 mini.Thanks forward
            tryed the beta version, and still cant connect over 16mbps, anything i could tweek anywhere
              Originally posted by HardwareGuru View Post
              For those who want to test.
              Live streaming apps are less supported like most roms but sound settings should be working perfectly.
              This i am working on:
              04c beta:
              http://www.freaktab.com/showthread.p...490#post152490
              I hear good things about your Rom, for someone like me that come with other device, what is the procedure to flash your Rom?
              - I have Ugoos UM2 WiFi chip rk3188 ap6210.
              - CUSTOM ROM: MK902 - Neomode Custom Rom V.1.0
              For example, if flash your Rom and stay with the Kernel I'm using on Neomode Custom Rom V.1.0 ¿will it work? Thanks
              -Chromecast with Google TV
              - Android Q Android 10
                I have a solution for you.
                With es explorer, open the root explorer to''on'' and mount r/w to rw both of them, path and system.
                Then go to system/etc/firmware and make a copy of 'nvram_6210.txt'' to anywhere else in sdcard,then rename it to nvram_ap6330.txt, and copy it back to the system/etc/firmware folder, if everything you did was right, you wiil be promted to overwrite, hit yes.
                Then restart your stick and check your wifi!!
                Hope that helped, i use this trick for every rom that is designed for 6330 sticks and boxes!!
                Happy explorations mate!!!
                  Melee F10
                  Love your rom
                  Found a bug in rom 03 did not see it in the changelog for 04 or 4c
                  when inserting the melee f10 usb dongle the option spdif pasthrough dissaper in de sound manager
                  not capable of having 5.1 output over optical spdif.
                  steps to reproduce : go to android sound manager insert f10 dongle you see it changing.
                  rom 03 losing sound settings after a while (minix always on) looks time related.
                  always need to delay the audio by 250 ms can you fix it dat its already delayd by 250 ms an the slyder on zero?
                  configuration:
                  my system is connected by optical spdif cable to 5.1 amplifier, sytem running rom 03.
                  keep up the good work.
                    Originally posted by compostbak View Post
                    Love your rom
                    configuration:
                    I can confirm the bug with f10 dongle, passtrough disappears..
                      Flashing another kernel.img will not work, you also have to flash the boot.img from the other rom and hope it is compatable.
                      If all is good this is solved in 04c..
                      Can anyone confirm this?
                        I'm running 04c... So the problem is still there...
                          That will only fix wifi, Bluetooth will still be unavailable. The best fix is to use a kernel with the right support built in
                          Using my ipad so apols for any stupid ios spelling 'corrections'
                          Donate to Finless
                            Re: HardwareGuru Rom 04 - Firmware for Neo X7
                            I just checked. In the sound device manager you chould be able to scroll down to see the passthrough options. The options are outside the window but you should be able to scrolle down ( or hold mouse button and drag up and down ) see if that works please.
                            Verstuurd vanaf mijn GT-I9105P met Tapatalk
                              With the f10 dongle detached I can select the passthrough option, but as soon has I plugin the f10 dongle, the passtrough disappears...
                                And you can't scroll to the pass through options at the bottom ? That's weird I run the same setup on a x7 do you run a x7
                                Verstuurd vanaf mijn GT-I9300 met Tapatalk
