PMID702C
Google apps!
So it turns out it's trivial to install Google apps on the device - I stumbled across APKTOP - questionably legal, but they have download for all of the Google apps - GMail, Maps and YouTube all work. The Play Store unfortunately crashes but that is probably because some dependency is missing.
Further, when I 'adb shell' into the device, I'm happily presented with:
Code:root@android:/ #
Enjoy!
I had no trouble at all with the Google Market. I basically followed the directions here: http://www.freaktab.com/showthread.p...rket-and-more!
EDIT: To clarify, I used N4RPS's instructions. The device is rooted and /system is already R/W, so some of the steps aren't needed.
PTAB?
Sounds like same one I got my wife today, but ours is Marked PTAB702C. Market fix in http://www.freaktab.com/showthread.p...Uploaded-File) worked fine.
Originally posted by rc1ark View PostI had no trouble at all with the Google Market. I basically followed the directions here: http://www.freaktab.com/showthread.php?491-****OFFICIAL-Polaroid-PMID701c-THREAD!-root-market-and-more!
EDIT: To clarify, I used N4RPS's instructions. The device is rooted and /system is already R/W, so some of the steps aren't needed.If possible, could you tell me exactly what steps are not needed? Thanks
Originally posted by garnetrose1927 View PostI just got the PMID 702C yesterday. I've downloaded and installed the amazon app. My question is why isn't is showing on my apps page. I'm not very tech savvy...sigh...not sure why I get into all this tech stuff...lol
Just install vending.apk?
Actually, I think it's even easier than those instructions, because we're already on ICS. Here's what I did...
I took this Market APK: http://www.apktops.com/android-market-3-2-0.html
copy it to system/apps/vending.apk. If you have adb installed, this is as easy as:
Code:adb push Android_Market_v3.2.0.apk /system/app/vending.apk
Code:adb shell "chmod 644 /system/app/vending.apk" adb reboot
I had also copied over a GoogleFrameworkServices.apk from a ICS gapps package I had for my Galaxy S but I'm pretty sure that wasn't even necessary.
I also suspect this would work if you copied over the latest Google Play APK that's on APKTOP, but it's not necessary since the market app updates itself as I said, you end up with the newest version either way!
Originally posted by major_thom View PostHas anyone tried installing ClockworkMod recovery? I installed the ROM Manager app but I haven't installed the actual recovery... I don't want to risk it
Last I checked clockworkmod does not work with ICS Allwinner chip set, yet. It does however work fine with gingerbread.If at first you don't succeed; call it version 1.0
Would I be better off exchanging my PMID701i for a PMID702c? It's sounding from posts folks have made here like the wifi is better on the PMID702c than on the PMID701i and doesn't cut out as bad with low connections. Only thing is my Big Lots probably doesn't have the PMID702c and since I bought my 701i Apr 29 I think, the time period for taking it back may have expired.
Or is there anything I can do or download to make the wifi better? Love the tablet, it's a good one so far, just not keen on dropped signals when the wifi connection gets poorer or further away.Tablets: Polaroid PMID 701i, PMID 4311, Zeki 10" tablet
"God Loves You"- Arlo Guthrie
Originally posted by helpless automation View PostI did run into an issue. The G sensor does not work in temple run. I am not sure what the issue is because the screen does rotate correctly on the home screen. I tried both the default and the special coordinate system with no luck. I bring this up because on both the 701i and the 701c it runs fine. If anyone has any ideas i am all ears.
Wifi seems to be good and touch screen is responsive. Camera is typical for low end tablets.
I hope the g sensor can be fixed by a firmware update or tweak since this seems to be a nice tablet.
There are currently 2475 users online. 0 members and 2475 guests.
