I've flashed my tablet with this ROM and is has all of the nice features of KitKat. We may have lost some of the game apps that came with the previous firmware, but there are plenty of emulator apps in their place...and full access to Google Play Store.
You will notice that JXD has removed the bottom navigation bar, to entice you to use the external buttons (there's a learning curve with that for me).
It runs really smooth. Wifi is improved. I haven't tested Bluetooth.
My son is now currently testing the gaming features, so I MAY get the tablet back for more testing someday...
Since this is a KitKat ROM, you must flash the loader in the flash tool. It's checked by default. If you decide to go back to the Jellybean ROM (I couldn't imagine why)...first erase IDB from THIS ROM kit...then open the Jellybean and flash...BE SURE TO CHECK THE LOADER or you will brick your tablet. Consider yourself warned!!!!!!!!!! That way I have the right to give you shit for not following these SIMPLE instructions when you ask me for help to unbrick your device.
This ROM is somewhat debloated. I left more in than usual, just because it's a gaming machine and should have some bells and whistles to start out with.
Also:
Rooted
Init.D Support
Busybox commands added
English Default
2. 4. 6, 8 or 12gb user app space (4gb default) using the desired parameter file
TWRP Recovery (installed after the first boot to allow stock recovery to format everything)Thanks to FT Developer Abdul_PT.
Auto Install apk files from external SD on first boot. Just add the apk files to a folder on external SD called autoinstall...delete all spaces from the apk file names.
Boot Animation by Tattman65
Reboot App by Petrus
v1.2.1 contains Tincore Keymapper by FT Developer Tincore
First Time User's Guide with all installation instructions and tips
This is now v1.2.1. There is a more aggressive debloat, spoofing as a Samsung device to open more Play Store apps, and Tincore Keymapper.
Download
If you want less aggressive debloat, more of the stock apps were left into a new 1.2.2 version.
Download
Enjoy!!!!!!
Please buy be a beer if you like the ROM...my donate link is always in my signature.
