JXD Game Pad 3 - S7800B - RileyROM 1.2 KitKat
Originally posted by badbojus View Posti have tested all kernels, after flashing them u getting black screen.
I set CPU to 1.7Ghz instead 1.6Ghz increasing voltage of 25mV, in my opinion it should work...
I think there is another limit elsewhere...if you appreciate my efforts this is the link for any donation:
Originally posted by badbojus View Postsorry if i am not right but i read somewhere that on this device is something dificult of increasing voltage ?
for my tablet I use 1.7Ghz at 1.275V. So I thought your gamepad should work with stock voltage!if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Postin any case as defaut it is set at 1.35V for 1.6Ghz.
for my tablet I use 1.7Ghz at 1.275V. So I thought your gamepad should work with stock voltage!if u have time to make more, i have plenty time to test later today (have to work 4h) !
Originally posted by Kaali View PostThanks Riley, it's the best rom so far i ever use for my JXD, but i think i've found a bug, the headphone jack output doesn't work, when you plug the headphone, sound continued to play on speakers, could anyone test it, to see if i'm right ?! maybe my headphone jack output is dead ...
rrileypm first at all, thans for your work;
can you also, at the next update, to show the bottom navigation bar (very important) and to assign a function at the physical button with on the joypad? Now it is dead.My Devices: Honor 6, Cx-919 (finless 2.0), JXD S7800B (RileyROM 1.2)
Originally posted by Scellow View PostFound two issue:
In recovery menu, the screen orientation is wrong
Power button doesn't work in recovery menu, i had to press the reset button
I just include his recovery in my ROM, he's the one who develops that part.
Randy
Re: JXD Game Pad 3 - S7800B - RileyROM 1.2 KitKat
What should the power button do?
It lock's the screen on recovery i disable that option.
Use the touchscreen
Tapatalked
Thanks, Abdul...I didn't know you would see this thread.Randy
A thing that should really be added is the possibility to mount the external sd as the internal memory... i can't find the vold.fstab... i've found three different fstabs and modified all of them, but at reboot they resetted themselves and nothing happened
Anyone has found a way to do this ?Overclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
Originally posted by stillsmile View PostLooks like I have bricked my console by reroll to JB... No signal with USB connection... Any ideas?
Originally posted by pogodancer View Post
There are currently 2800 users online. 0 members and 2800 guests.
