.gif)
JXD Game Pad 3 - S7800B - RileyROM 1.2 KitKat
Re: JXD Game Pad 3 - S7800B - RileyROM 1.2 KitKat
Originally posted by abdul_pt View PostIf the issue is the portrait orientation, that's not an issue. It's the way your screen is.
If the issue is the screen refresh it's a reported bug.
I made two new images.
TWRP JXD bgra
TWRP JXD rgb
Thanks...I will test it. But it will be tomorrow.
RandyRandy
Originally posted by Maetel View Posti made a full backup of jxd keymapper from 1.1.4 and 1.1.5 roms with titanium backup, installed kikat rom and try restore the backup without sucessthe "restoring" message neve ends.
There must be something in this new firmware that makes it not compatible.
RandyRandy
Originally posted by rrileypm View PostThere must be something in this new firmware that makes it not compatible.
Randy
so i googled and came back to freaktab
he got somekind of patch for stock mapper. maybe you can ask him ??
just helping out
i didnt installed on this rom.incase of brick.
Originally posted by tamil112 View PostMy Devices: Honor 6, Cx-919 (finless 2.0), JXD S7800B (RileyROM 1.2)
I am not sure about 7800B, but in previous devices like 5110B or 7300B (you can find my ROMS here in the amlogic section), the keymapper has never been an apk, it's embedded into the system framework, specifically in android.policy, framework.jar, and framework-res, with a call via kernel side to the joystick driver used and needed for his mapper. To include it it was necessary to compile the whole sdk from amlogic. It was like that in previous devices, so if this Kitkat for 7800B has no mapper is probably because they don't know how to include it. JXD has changed of software company, and probably the new one has not included yet. If the JB firmwares have stock mapper, you can check if they include an apk, if not, then it's probably embedded into the framework files too.
Originally posted by skelton View PostI am not sure about 7800B, but in previous devices like 5110B or 7300B (you can find my ROMS here in the amlogic section), the keymapper has never been an apk, it's embedded into the system framework, specifically in android.policy, framework.jar, and framework-res, with a call via kernel side to the joystick driver used and needed for his mapper. To include it it was necessary to compile the whole sdk from amlogic. It was like that in previous devices, so if this Kitkat for 7800B has no mapper is probably because they don't know how to include it. JXD has changed of software company, and probably the new one has not included yet. If the JB firmwares have stock mapper, you can check if they include an apk, if not, then it's probably embedded into the framework files too.
cant you build one of your roms for this sweet gamepad?
Sorry to hear that. I was hoping you would continue your support...any particular reason? You can PM me if you like.
Sent from my M6Pro using TapatalkRandy
rrileypm, we certainly appreciate your work, your rom is the only with android 4.4, but i think we wish only some basic feature:
add bottom navigation bar
map keymapper physical button (for tincore or another. It's a pity that now that button is dead)
fix headphone
add a Battery Charge Indicator (when we charge the device, we don't know if it 100% charged, if we push lightly the power button, it turn on the device :\, i've never seen that in my life)My Devices: Honor 6, Cx-919 (finless 2.0), JXD S7800B (RileyROM 1.2)
1.4/1.6GHz
Just was wondering - will the KitKat update (JXD_S7800B_RileyROM_1.2.1.zip) work on the 1.6GHz too?
cheers
It should...it works on mine.Randy
Riley rom 1.2 KitKat
I am very new to android and purchased the tablet from dinodirect
delivery too forever
i was very happy to receive it i good working order
I sa you rom whilst i was searching and after reading the comments decided to install
I had no luck using win 8.1 but luckily i had another pc with xp
using your instructions everything went smoothly and with no problems on install
Thank you very much for all your hard work
and your consistant help with those that have problems
My only issue seem to be using the controls and joystick whilst using any ds game
I do have tincore installed and that does not seem to operate all buttons
I have only the tincore free version at the moment
i used gamepad test and the analog buttons seem to work
although the joystick control only move one click in each directions
a popup box comes up and says my profile has add-on functionality and want me to purchase premiunm app
1. do i need premium tincore in order to use the jxd gamepad in order to use the analog controls on my gqme pad
2. should the analog controls work in drastic emulator for ds
once again
thank for a very designed rom - very happy with it
please forgive if my questions sound stupid
but i am searching the net for answers as well
Originally posted by rrileypm View PostI've been testing mine also.
My first ROM's were not as aggressive with debloat, but I'm now removing most of that crap, now.
I may do a complete update, soon.
Thanks for the feedback!!!!!!
There are currently 2055 users online. 2 members and 2053 guests.
