JXD Game Pad 3 - S7800B - RileyROM 1.2 KitKat
I believe I left the keymapper in place in this ROM...it should work.
Here's a link to a different keymapper app that should work, also. Thanks to FT user Skelton. He posted it on his JB ROM thread for the GPD G7.
Randy
This thread has moved to the Rockchip Gaming ROM section.Randy
Originally posted by rrileypm View PostI believe I left the keymapper in place in this ROM...it should work.
https://play.google.com/store/apps/d....and.keymapper
Well, I guess that now my device is done for good.
After that failed update I started to try some things to revive it.
I managed to get it in the "Blue Square Mode" on Batchtool.
I started to flash it... buuuuut.... I got a BSOD halfway of the process...
Now it can't even get recognized by Windows...
Any advice? Tips? Hints? I'll take anything!!! Help!!
Thanks in advance.
Originally posted by Edzward View PostWell, I guess that now my device is done for good.
Thanks in advance.
Originally posted by badbojus View Posthello, so i still can not install kitkat rom anymore,every time it flashes without errors but cant get out of recovery, i ofcaure erased nand and tryed all other ways i know.. any suggestion ? also tryed from rilay v.1.1 go to kiktat and got same thing, tryed also flas misc.img from pipo forums, tryed misc from v1.1 so no luck...
i want still install this rom, since i found nice nav bar app ...
When you flash a KitKat ROM be sure to check the loader...on my ROM it is checked be default. I tested this on my tablet, so I know it works. Although I did have to click reset once on first boot.
I have a new ROM I have not tested yet I can post. I just have to get my device back from my son to test it. Stay tuned for a link.Randy
Originally posted by rrileypm View PostWhen you flash a KitKat ROM be sure to check the loader...on my ROM it is checked be default. I tested this on my tablet, so I know it works. Although I did have to click reset once on first boot.
I've just uploaded v1.2.1 to test:
Download
I've done a more aggressive debloat and spoofed as a Samsung device to open up most apps in Google Play Store.Randy
hahahaha!!!!!!!Randy
There are currently 2825 users online. 0 members and 2825 guests.
