Sent from my Teclast A10HD / Jelly Bean 4.2.2 using Tapatalk 4
JXD Game Pad 3 - S7800B - RileyROM 1.2 KitKat
I've had several requests for an update to this ROM with less debloat of the stock apps. Also, I did not update Google Apps this time (I left the stock version in because it was causing some force closes of some apps).
Here is V1.2.2
DownloadRandy
I believe so. I didn't remove anything.Randy
I looked throughout the stock version of the firmware this ROM is based on, and I couldn't find a Keymapper app from JXD. I went back and took the one from the 1.1 stock ROM...and here it is:
Try installing this app and see if it works.
You may need to copy it into system/app folder and give it execute permissions for it to work right.Randy
BTW, I tried that TWRP recovery on my device.
Since it defaults to portrait mode, the right half of the screen is cut off. The actual orientation of the TWRP is upside down portrait mode.Randy
Originally posted by rrileypm View PostBTW, I tried that TWRP recovery on my device.
What I intended to say was it was a known issue...sorry for the misunderstanding.
The up side is that we should have a solution pretty quick.Randy
Originally posted by rrileypm View PostI looked throughout the stock version of the firmware this ROM is based on, and I couldn't find a Keymapper app from JXD. I went back and took the one from the 1.1 stock ROM...and here it is:
so download installed, rebooted, converted to system app, rebooted. nothing! it seems just a updater for the gamecontrole configure.
I guess that wasn't the stock keymapper after all. I will look some more in the previous ROM for some clues to its whereabouts.Randy
Originally posted by Scellow View PostRemenber i reported this issue and you guys said it wasn't an issue :3
If the issue is the screen refresh it's a reported bug.
I made two new images.
TWRP JXD bgra
TWRP JXD rgb
There are currently 2874 users online. 1 members and 2873 guests.
