Tronsmart Vega S89-H Amlogic S802-H Quad Core Android TV BOX 2G/16G 2.4G/5G WIFI Bluetooth XBMC Support Dolby and DTS
    Originally posted by Dandroid534 View Post
    SD card or usb stick
    Tronsmart s89-H
      Originally posted by Oualid2013 View Post
      Tronsmart s89-H
      You can do it with either an SD card or a USB stick, you unzip and then put rom onto either usb or sd card and update from there. Having never used android before i got this, it wasn't clear to me that you can update from USB as well as SD card. And considering I don't have an sd card that would fit, it was definately the simpler option!
        I have the Tonsmart Vega S89-H. I am unable able to passthrough dts-ma or dolby truhd. Only the core dts and dolby are passed through to my receiver as those are the signals lighting up on my receiver. I have an Onkyo HD receiver capable of decoding HD. I have HDMI passthrough set on the box and in XBMC i have passthrough checked but there are only options for dolby and dts passhrough for XBMC. Anybody having this issue or know a fix?
          Running Multiple S89H
          So I bought 3 S89-H, one for each TV. All 3 updated with Finless 1.6 and running a separate Ethernet cable from my router which is a TP Line AC1750. It seem that I can not run more than one at a time or it causes major buffering. My internet plan was a 25mps plan, which I upgraded to a 50mps plan and am experiencing the same thing. Is anyone else experiencing this and what is the fix. Please Help
            I have the same issue, caused by all the devices having the same MAC address.Still looking for a perm solution.
              Ty geekbuying my box is here today great box
                mine turned up aswell Woo Hoo!
                so far the only issue is my 1080I TV must have a very old HDMI version, because the picture is offset to the left too far, even if i put the screen size at it's lowest setting of 80%, it still offset, I went into my TV's settings and have offset to the right as far as it goes ( +30 frames ) but still not right...
                Have tried the unit on a friend's newer TV and its fine... Looks like it's time to buy a new TV
                Sent from my Commodore 64 using Geos
                My devices:
                Tronsmart Vega S89-H: running stock 104k4 rom, rooted & racky's cpu fix.
                Samsung Galaxy Tab 10.1: running KK's dual boot kernel, Phil's touch recovery & de-bloated, over-clocked and rooted stock rom.
                Samsung Galaxy S3: stock until warrany is over lol running JB 4.3 ...
                HTC Incredible S: Venom rom, 'kangaroo' kernel, overclocked to 2Ghz & still kicking the Sammy's butt!
                  Hello got the Vega S89-H XBMC plays gread everything HD, 3D. The only problem is when I try to play avi files quality looks horrible. The only way to make it look good is turn off amcodec under video options, but when I do that xbmc crashes on all MKV files. Alonso tried changing to software instead of hardware decoding then HD is choppy. Any suggestions?
                    Finless turned me on to this, here is his email below:
                    Use this one. It is tuned just for the S802.
                    http://www.freaktab.com/showthread.p...-s802-platform
                    Works well for me. It is a tweaked XBMC and I installed FINLESS 1.6
                      did you have to pay tax
                        No Tax with dhl  and is very good box
                          Hi Guys, I got my replacement unit and so far so good. Awesome job Geekbuying.
                          Has anyone else got Mizuu working properly on it. In particular watching movie trailers. It uses Youtube to play the trailers but when I play them I have sound but no video. I have googled and can't find anyone else with the same issue. I have messaged the developer but no luck as yet. Is anyone able to test it and let me know if it works for you on your Vega s89-h (or other variant I imagine). Thanks.
                            Did everything you suggested. No quality changes. Installed finless and tweaked xbmc. avi have horrible pixels on faces. MKV and mp4 are good.
                              I just tested Mizuu for you on my S802-H, I have the same problem.
                                Thanks for testing that. At least I know it's not just me. Anyone out there know how we might fix this? I love Mizuu but the trailers was one of the things that appealed to me.
