Tronsmart Vega S89-H Amlogic S802-H Quad Core Android TV BOX 2G/16G 2.4G/5G WIFI Bluetooth XBMC Support Dolby and DTS
    For some reason I cant get Google Play working straight out of the box on my vega; I keep getting a no connection error even though my browser can access the web.
      it wont connect right out of the box i received an email from geek butying a day before mine showed up here you need the 104k4 rom
        http://blog.geekbuying.com/index.php.../#.U4az5ShspVI
        it looks to also fix live streaming issues via XMBC that others have posted ... Eric is definately on top of things.. great work
        Sent from my Commodore 64 using Geos
        My devices:
        Tronsmart Vega S89-H: running stock 104k4 rom, rooted & racky's cpu fix.
        Samsung Galaxy Tab 10.1: running KK's dual boot kernel, Phil's touch recovery & de-bloated, over-clocked and rooted stock rom.
        Samsung Galaxy S3: stock until warrany is over lol running JB 4.3 ...
        HTC Incredible S: Venom rom, 'kangaroo' kernel, overclocked to 2Ghz & still kicking the Sammy's butt!
          Isn't this the latest firmware, correct me if I'm wrong --> http://blog.geekbuying.com/index.php.../#.U4bKJWxZr4d
            finless 1.6 is built off the 104k4 rom yes im just waiting to hear if there are any issues using the -h with it
              My -h is working fine the second day on finless 1.6 couldnt figure out any technical issues to stock rom till now
              I hope you have fun with my english writing!
              Now Draco Meta...coming from Vega S89-H, wdtvhd 1, xtreamer 1, zotac ion, raspi and some android smartphone skills
                Launch Directly in XBMC
                Does anyone know if there is any way to boot directly into XBMC on power up either with the stock launchers or another launcher? I'm using the current Finless 1.6 ROM on the S89-H.
                Similarly I know if I put the S89-H in standby with XBMC launched on wakeup XBMC will remain loaded. Is it good practice to always leave the device in standby or should it be turned off nightly?
                Any insight would be appreciated. Thanks.
                  You can set xbmc as a home launcher with a modified build.
                  In xbmc you can switch to the installed apps by... “programs-> Android Apps“
                  I'm testing it right now and it seems to work fine for me.
                  Although I'm not sure if it has something to do with my wake up issues...
                    I didn't install the Finless Rom for the H but I read that it has heating issues, anyone else has that problem??
                      Vega S89-H Plex Client no DTS/DD Output Please HELP!
                      Hello,
                      I just received my Vega S89-H a couple days ago. Everything working great except a couple minor issues but I am having issues getting Plex Client to output DD and DTS to my HT. This feature works great via XBMC but not through Plex. Anyone have this issue? Please advise how to resolve this. I would really like to continue using this box.
                      Thanks,
                      Maestro
                        Same issue here....
                        Having exactly the same issue and can't seem solve this....
                        Originally posted by maestro7954 View Post
                        Hello,
                        Thanks,
                        Maestro
                          I had a similar issue, but not with plex. Make sure digital audio auto-detection is turned on. That corrected my problem of no Dolby Digital from my other video players.
                            Could you get digital out with plex?
                              I get mine today. Is there anything I should be doing to it such as installing another rom or anything else?
                                At the moment only check if you already use stock rom 104k4...
                                You can also try Finless 1.6 , but it seams there is something different at -h and non -h stock roms and the Finless 1.6 base on the non -h stock rom, but it seams 'only' in heating (maybe 10°C more with Finless 1.6 instead of stock rom 104k4)...
                                RK3288 Devices
                                - Overview BOX (LINK !)
