Help!mk809 with rk3188+rtl8723bs wifi&bt chip
    Hi, I bought a mk809iii with a rtl8723bs chip. But the roms I found here seems don't support this specific wifi&bt chip(Couldn't use wifi as well as bluetooth). Any one knows where could I find a suitable rom for this stick?
    Thanks in advance!!
    Hi
    Did you find any solution for wifi? I have the same chip and also no WIFI after installing picuntu on my mk809iii (rk3188-t / rtl 8723 bs). There is very little reference regarding this specific wifi chip on the internet.
    Regards
    Peter
      I too have the same problem! It annoys me like hell! Only thing I can say is: DO NOT flash images from UGOOS, it will brick it.. Took me quite some time to figure out how to get it back!
        bricked!
        Sorry I can't find any suitable solutions and the device has been bricked after flashing so many times!
        Originally posted by peterb View Post
        Hi
        Regards
        Peter
          How to save it after bricked?
          Hi, buddy, how to get it back?
            Same problem
            Hi!
            Same problem.
            I upgraded, and now nothing works.
            Not the right description sent. Taken apart.
            (MK809IV)
            It turned out that I did not stick rk3188 AP6210 and Wi-Fi module.
            This rk3188t rtl8723bs with wifi / bt chip, looking for the right rom.
            Please who can help.Sorry my bad english...
            [email protected]
            Thank you!
              hi guys. i have the same problem. i had save 8327bs.ko module from another mk809iii and i tryed put it into /system/lib/modules of neomode1.9a but no work. can somebody help me to patch the meomode rom with this module? it is possible?
              thanks everyone!
              8723bs.ko
                thanks everyone!
                8723bs.ko
                Yes, I've tried doing similiar things but have no luck. Turning on wifi on settings, but it shows there is no any wifi networks.
                Any clue how to debug the issue?
                  You have to insmod the 8723bs.ko module.
                  Also might need a kernel with 8723bs wifi enabled.
                    RK3188T + rtl8723bs working
                    百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
                    Hi, this one worked for me. I believe its the stock R-box firmware
                      dongle + rk3188t + rtl8723bs wifi&bt chip
                      Hi!
                      Thank you!!!!!
                      I download and try...
                      Best Regards: Attila
                      ( from Hungary )
                      I later write... ( what is the result )
                      sorry my bad english
                        rk3188-t and rtl8723bs wifi & bluetooth
                        Originally posted by intrepid View Post
                        http://pan.baidu.com/s/1i31HUmh
                        This firmware(ro.vendor.sw.version=RK3188_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130514) works great.
                        Some of the output of `dmesg | grep WiFi`
                        <4>[ 1.934376] Rockchip WiFi SYS interface (V1.00) ...
                        <4>[ 4.309246] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
                        <4>[ 4.309313] Realtek 8723BS SDIO WiFi driver (Powered by Rockchip,Ver 2.02)
                        init.
                        <4>[ 23.435952] Current WiFi chip is RTL8723BS.
                        I can see there is a module named 8723bs.ko in /system/lib/modules, but there is no any reference to it doing a module insert operation in system partition. `lsmod` doesn't show 8723bs loaded, but it does work well with this firmware.
                        Finally, I got it from init.rk30board.rc in boot.img,
                        on boot
                        insmod /system/lib/modules/8723bs.ko ifname=wlan0 if2name=p2p0
                          Work!!! Thank you very much!
                          Hi!
                          Thank you my friend!!!!!
                          Work!
                          ICS firmware exists in this version?
                          I can not download from the play gta sa, not shown in play store.
                          build.prop in what I write out?
                          Rk3188-t work stable 1.6Ghz!!!, its normal? Not only 1.4Ghz?
                          I put cooling now. Very hot the soc..
                          Please help!
                          Thank you!
                          Attila from Hungary
                          My stick:
                          Upload mirror the rom here:
                          Picture...
                          Or here:
                            it works fine me to!
                            thanks so much!
                              how to find the firm?
                              Hi!
                              How to find, found on the site firmware? Paidu ....
                              Sry my bad english
                              Thank you!
