Help!mk809 with rk3188+rtl8723bs wifi&bt chip
Thank you
Originally posted by mongkok View PostFor those who have trouble rooting the stick. Make sure you install the RockChip drivers. The driver you installed for flashing is not enough.
When you need to root or upgrade Rockchip RK3066 or RK3188 devices, you'll usually have to connect your device to your computer via USB, and in Windows,
There is a even simpler way by using custom ROM. The following ROMs work:
But the Wi-Fi / BT does not work. The trick is that you need to replace the kernel.img with the one built by d33:
http://www.freak-tab.de/d33/kernel_K..._RTL8723AU.zip
Thank you for your instructions.
Unfortunately the kernel download link does not work.
Is it possible to get from another source.
Thank you in advance.
ovika
ovika
http://www.freak-tab.de/d33/kernel_K..._RTL8723BS.zip
If someone found another ROM, especially one that has 1080p and/or rotation, that has BT working with d33's kernel.img. Please share.
Root problem
Hello !
First of all thank you for all information about rooting.
I tried several times (min.25). And do you know what the error were???
I did not connect the stick to my pc.
Maybe i lost my mind.
But now this little guy is rooted.
Vroot made it perfectly.
Thanks mak2 and mongkok for help.
ovika
MK809III WIFI RTL8723BS FIRMWARE
Hi guys,
I'm newbie here.
I have a MK809III (RK3188T running 1,4Ghz 2GB ram, Wifi RTL 8723BS). I think is the same as UGOOS UG007B.
Currently it's running Android 4.4.2, build number rk3188-eng 4.4.2 KOT49H eng.root.20140708.183130 test-keys
I have found a site with roms for these devices. Check it out.
You can find there latest firmware for wifi rtl 8723bs based tv stick:
MK809III UG007B 8723 Android 4.4 1080P Firmware (The new firmware is for MK809III/UG007B with 8723 WiFi Module)http://ugoos.net/index.php?route=pro...download_id=56
287.3MiB added 11/13/2014
NewFirmware
Originally posted by franpla83 View PostHi guys,
I'm newbie here.
MK809III UG007B 8723 Android 4.4 1080P Firmware (The new firmware is for MK809III/UG007B with 8723 WiFi Module)http://ugoos.net/index.php?route=pro...download_id=56[ATTACH=CONFIG]8884[/ATTACH][ATTACH=CONFIG]8885[/ATTACH]
have you tried this new firmware??
Originally posted by franpla83 View PostHi, not yet, I have no time, and current rom works fine. Maybe next month. But this rom seems the right for this device
But in current rom ther is no support for ' Remote control with android smart phones' (keybord and mouse over android smart phones). Am i right?
Re: Help!mk809 with rk3188+rtl8723bs wifi&bt chip
Originally posted by sokre57 View PostBut in current rom ther is no support for ' Remote control with android smart phones' (keybord and mouse over android smart phones). Am i right?
Originally posted by franpla83 View PostIn my current rom, I have full support for remote control , from my android smartphone ( app is RKremotecontrol, search it at minix website. Other apps not working) and from my measy rc11 keyboard-mouse (with standard 2.4 Ghz usb plugin).
Originally posted by Sega View PostCyanogenMod 11(android 4.4.4) radxa rock на базе rk3188 , with wifi realtek 8723
https://github.com/jungleji/android_...arock/releases
There are currently 2034 users online. 4 members and 2030 guests.
