Help!mk809 with rk3188+rtl8723bs wifi&bt chip
    Originally posted by jolund View Post
    I'm sorry I'm newbie. What is DMESG ?
    "dmesg (display message or driver message) is a command on most Linux- and Unix-based operating systems that prints the message buffer of the kernel."
    dmesg is emulator command - run terminal emulator then login as root - use
    Code:
    su
    and then
    Code:
    dmesg > /sdcard/Downloads/file
    /sdcard/Downloads/file is example location that will print the output to file.
      this link is down!
      Originally posted by d33 View Post
      Please provide stock DMESG & GPIO and the DMESG from this build
      kernel_for Kit Kat_with wifi_RTL8723bs
      Hi d33, where can I download this image? For me this link is down.
        Code:
        su
        and then
        Code:
        Unfortunately I don't have linux
          You just need to download terminal emulator from the play store
            ok
              The link doesn't work, I cant download the kernel.
                Here my DMESG: https://www.dropbox.com/s/sfvpgjzymy5148r/file
                I used dropbox coz I don't know why but there is an error attaching the file in this forum.
                Now both kernel and wifi work but the stick is hot. I have the 3188-T version and I've set the processor to 1.4GHz.
                Can you add the Full-HD, please?
                Also, I'm having problems installing APKs. I've tried to install netflix and the fix from xda forum. It shows me "there was a problem parsing the package". How can I solve this?
                Thanks!
                  1. I see the wifi works
                  2. You need to upload zips to the forum
                  3. The kernel is HD already
                  Donate to Finless
                    Yes thanks very much. the wifi works.
                    when i set 1080p the image doesnt cover all the screen, so i need to enlarge it and there are some brilliant weird lines and points. I think it is flickering.
                    could you add lower frequencies than 500? it is useful if i leave the stick always on.
                    I have 3188t version and it is hot.
                      The stick reboots often and I can't use it. I think it is because of the overheat problem.
                        the device reboots because of high energy consumption - try using another cable (I switched to the original Nokia one - and it works). This is because the kernel is really high-performance - antutu shows 19k.
                        But the BT still doesn't work
                          4.4.2 Root
                          Hi guys,
                          If you have updated to the official 4.4.2 firmware but like me have struggled to get it rooted, I have finally found the following and can confirm it works!
                          http://www.mgyun.com/en/GetVRoot
                          I now have 4.4.2 working with root. Hope this helps.
                            hi. i made original dump R-BOX firmaware from my mk809iii rk3188-t rtl8723bs.
                            i followed this guide: http://www.freaktab.com/showthread.p...ew-RK-2-1-tool
                            "thanks Finless"
                            this is my dump:
                            https://mega.co.nz/#!3VxzGJgY!iX3Mau...nJfhF3O9Nzzp2o
                            note: i made factory reset before the dump
                            this is the flash tool:
                            MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
                            unzip output.zip and .rk_dumptool.zip.
                            put the complete folder output into the root RK Rom Dumper and Flasher for Windows folder.
                            use ROM_Flash_Tool_137.exe (into flasher_tool folder) to flash rom.
                            good luck
                            sorry my bad english
                              How to flash
                              I'm a complete newbie in Android world. How can I flash the update_tv03 8723 4.4 内置xbmc_2014.7.8.img.... Can I use the RKAndroidTool from Neomode... What I have to do, just replace the system.img of the Neomode by this one... what else I have to flash... or just the system... Thanks a lot...
                                I have built a kernel for RTL8723BS (hopefully) with bluetooth support working.
                                Download
                                Kernels are 1920 res (HD) or 1280 (SD) and TVBOX supports typical BOX configuration using RK1000 (TV out / Audio codec) whilst TV Stick is simpler version for HDMI stick devices.
                                Donate to Finless
