Help!mk809 with rk3188+rtl8723bs wifi&bt chip
kernel 8723
Originally posted by d33 View Post
Root
Hi gigirock,
You can root the stock 4.4 firmware using an app called vroot.
Parts of it are in Chinese but it works ok.
Originally posted by gigirock View PostHi D33, new member here... I have installed the new stock 4.4 rom mentioned above and all went fine. I still haven't found a way to root this KK rom but I just learned how to use "upgrade_tool" and "rkflashkit" both on linux and flashed your kernel. Unfortunately wifi doesn't work and I still can't see a real 1080p. Anyway... Thank you very much for your efforts.
Didint work
I tried to use VROOT, but it doesn't work... It keep saying to connect my "phone"! Even with USB Debug enabled...
Originally posted by gigirock View PostHi D33, new member here... I have installed the new stock 4.4 rom mentioned above and all went fine. I still haven't found a way to root this KK rom but I just learned how to use "upgrade_tool" and "rkflashkit" both on linux and flashed your kernel. Unfortunately wifi doesn't work and I still can't see a real 1080p. Anyway... Thank you very much for your efforts.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Root Succeded
Originally posted by gigirock View PostUnfortunately I haven't been able to root it , also with vroot... I'll try again... Moreover... I don't understand chinese...
Originally posted by predshaw View PostNice one, well done!
Whilst it is a stock rom I actually think it runs pretty well, and most importantly everything works!
Anyway... D33, I will try again your kernel and try to post a dmesg of my boot...
Originally posted by gigirock View Post... I deleted the file from my pc and your kernel in not downlodable anymore...Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostDownload from first post of "Kitkat kernels for all" thread
Originally posted by gigirock View PostI am sorry... I really couldn't find it... I just found this one related to you and kitkat kernel: http://www.freaktab.com/showthread.p...Kitkat+kernels
Originally posted by gigirock View PostI found it!
I don-t see any improvements in resolution and if I use the app Android Hardware Info it tells me that the "display" is 1280x720 @ 160 dpi......
DMESG and screenshot attached.Attached Files
There are currently 2029 users online. 1 members and 2028 guests.
