Does anybody know if I can use Google now over the stick if I connect the stick as a Bt phone over a car head unit?
My appradio3 shows "voice recognition) but nothing on the stick side.I have ticked on the offline voice recognition (i tried with wifi tethering as well but with non success) and the use Google now with Bluetooth headsets.
Finally, I think I have managed to flash the right firmware successfully!!
I used the Rockchip batch tool v1.7 to flash the update_tv03 8723 4.4 内置xbmc_2014.7.8
The wifi works, I have nothing to tests the BT, unfortunately it still seems to disconnect the HDMI every few minutes (even using a good power source) so it isnt perfect, but its the best one I have used yet.
The BT can be powered ON? Or the button backs to OFF after a few seconds.
Is it possible who owns a rooted img file to upload somwhere? I am fully lost. I tried all. I could root all of my android devices. But this stick is...
Thank you in advance.
Could you tell me something trick to get root acces for my stick.
I tried almost everything.
Always when i connected my stick to my pc (win_xp_sp3) vroot or kingoroot say:Not connected.
I switched on usb debugging, but zero.
I cheked my pc and it sees the device. I hope because there is :
[IMG][/IMG]
For my sorrow no success.
What is the problem in this case do you think?
I can flash the rom but i can root this little guy.
alloys usually the mk809iii (can be connected to the tv) you must mark the usb debugging then mark connects pc. You hear the sound connected to the pc and appears next to the clock as connected.
After you run the VROOT(http://www.mgyun.com/en/getvroot) clik connect device, waits to detect the device and you click on root, waits again the process has finished, click reroot after done. was ready and so I did. my OS is win7 ultimate
hope that helps.
excuse my bad english
GREETINGS
ps: no need to press the button resert
Connect the PC through the USB OTG port
When you need to root or upgrade Rockchip RK3066 or RK3188 devices, you'll usually have to connect your device to your computer via USB, and in Windows,
There is a even simpler way by using custom ROM. The following ROMs work:
