Help!mk809 with rk3188+rtl8723bs wifi&bt chip
SOLVED!
I registered here justo to THANK YOU!
Now my CX-919 is working, with full BT and Wi-fi.
Rooted with iRoot (http://www.mgyun.com/m/en)
Originally posted by omerook View Posthi. i made original dump R-BOX firmaware from my mk809iii rk3188-t rtl8723bs.
i followed this guide: http://www.freaktab.com/showthread.p...ew-RK-2-1-tool
"thanks Finless"
this is my dump:
https://mega.co.nz/#!3VxzGJgY!iX3Mau...nJfhF3O9Nzzp2o
note: i made factory reset before the dump
this is the flash tool:
MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
unzip output.zip and .rk_dumptool.zip.
put the complete folder output into the root RK Rom Dumper and Flasher for Windows folder.
use ROM_Flash_Tool_137.exe (into flasher_tool folder) to flash rom.
good luck
sorry my bad english
mk809IV no va wifi
Compré en aliexpress hace pocos dias un mk809IV con rk3188 + rtl8723bs y a la semana no funcionaba, no arrancaba. Le he cargado varias roms y algunas funcionan pero en todas ellas no va el wifi. Necesito vuestra ayuda para encontrar la rom que haga funcionar el wifi o si se puede de alguna manera instalar solo el wifi para que funcione. Muchas gracias.
Pardone mi espanol. Hable solo poco. Cual es el numero de version de su placa base?
Espero que eso es correcto :-)
Salud!
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
first post
Hey my first post!
Didn't read this whole thread(don't hate for a possible repost) although it would've helped me the other day when I was learning how to flash roms, but I have the same build/chipsets. I downloaded this rom and wifi works like a beast, it was absolute shit before hand(barely could hold a connection with antenna outside the case). Haven't tested bluetooth yet, but I assume it's working. The kernel is 1080p kitkat w/ no oc from what I can tell. i was working on one yesterday w/ the overclockomatic.exe (rkpatchomatic + rockchip unpk), but my otg port popped off when my dog bumped me before I could get a chance to flash it :/ Anyways heres the link that I'm sure someone has posted already.
I have as problem with my WiFi.
Sometimes the ROM boots without WiFi enabled and I can't enable it. When ROM boots with WiFi enabled it boots when connection is established with my s3 (WiFi tethering).
Could it be a damaged chipset?
I am on stock kitkat ROM 720p
Anyone tried neomode's one with both WiFi an BT working?
There could be a newer firmware available that might fix your issue.
Cheers,
Ayuda!!! Compre hace algunas semanas este modelo gtx_d16 lp v1.8 rk3188t + rtl8723bs
Probe varias rom la mayoría no inicia, un par de ellas inicia pero no funciona el Wifi y la única que funciona es D16BS_20150120.img pero el equipo se frezzea y reinicia a los pocos minutos de estar encendido.
D16BS_20150120.img Incicia funciona Wifi pero, se reinicia tras pocos minutos de trabajo
kitkat-gxtd16 Inicia, no funciona wifi ni bluetooth
¿cual es la rom correcta para mi dispositivo?
Originally posted by dferradans View PostAyuda!!! Compre hace algunas semanas este modelo gtx_d16 lp v1.8 rk3188t + rtl8723bs
There are currently 2192 users online. 4 members and 2188 guests.
