Lifeforce ROM - Firmware for the M8 Tomato
Bugs are Sons of Glitches!
JustMe
Originally posted by pigbait View PostHey guys, I unzipped the stock firmware from may 12th, to edit the config file for the 5ghz wifi fix. But when I re zip the firmware. I get a footer error when I try to flash it, how do I fix this.
Sent from my SGH-I317 using Tapatalk
Originally posted by rlaursen View Posti just noticed that if you turn the wifi on and off i get the same 65mbps speed as my other firmwares but it randomly dropped to 52 and back up to 58 after checking it a few times. It always gets the same speed as other fw if I turn the wifi on and off. Test that and see if you get the same results.
edit: just checked it again and it dropped to 13mbps lol turned wifi off and on.. back to 65 but there is def something wrong here.. it isnt a stable connection
edit: ran the 5ghz patch from bob and tested again. According to mbox settings(with color buttons on top) 5ghz band is showing 2/4 bars but in the android looking setttings page it says 3/4. I run same test on 5ghz and i get 18mbps consistently whereas 2.4 band gives me 8-10 with 4/4 bars . The 5g patch may have resolved this wifi issue im not positive though. I doubt it has any affect on the 2.4 band unless im mistaken
Originally posted by handroid View PostAbout the "5ghz patch from bob". Where can I find/download this patch?RK3288 Devices
- Overview BOX (LINK !)
New firmware
Hi all!
I did a firmware, because i really need the paid apps. (Full firmware)
http://www.220volt.hu/temp/upload/playa/m8/TM8_AP6330_20140517_Lifeforce.rar
- deodexed
- fixed a bug that not download paid apps (unfortunately, only a trick but it works)
- Google apps update
- root (su running as a daemon)
- Added init.d support
- Fixed Wifi problems with 5G
- Very unnecessary files removed (Chinese game)
I did not want to implement major changes (next time), people love to factory state.
Sorry my bad english
Cool!
- deodexed
- deodexed
we also need the tcp buffer size increased alot so we can get full ethernet speeds. thanks!
FYI, NEW Download from the vendor I deal with for my M8's
http://pan.baidu.com/s/1gdsZ9pL
supposed to have the DTS,AC3 fix. I have not tried it yet. Will try it tomorrow, thought I'll share.
Cheers,
tr
(edited to fix link)Last edited by therabbit; 05-19-2014, 12:40.
thanks LifetForce. makes me happy there some active development happing for this box and good community surfacing.
Thanks to all
JustMeLast edited by JustMe; 05-18-2014, 05:20.Bugs are Sons of Glitches!
JustMe
Originally posted by therabbit View Posthttp://pan.baidu.com/s/1gdsZ9pLsupposed to have the DTS,AC3 fix. I have not tried it yet. Will try it tomorrow, thought I'll share.Cheers,tr
JustMeBugs are Sons of Glitches!
JustMe
There are currently 2609 users online. 6 members and 2603 guests.
