Sent from my SGH-I317 using Tapatalk
Lifeforce ROM - Firmware for the M8 Tomato
+1 force,
Tested 3 so far
stock, 696, 816
Stock = 24102
696 = 23486
816 = 22240
Little confused now by this
JustMeBugs are Sons of Glitches!
JustMe
Your are not going to see an Antutu change with this patch. All this does is change the governor and the lowest speed the SPU runs. Antutu will push the CPU to max speed when it runs.
Also the scores you show are close enough! Every time you run Antutu expect a difference in the 1000 area. So your scores difference are not because of this patcher.
Originally posted by Finless View PostYour are not going to see an Antutu change with this patch. All this does is change the governor and the lowest speed the SPU runs. Antutu will push the CPU to max speed when it runs.
Thanks BobBugs are Sons of Glitches!
JustMe
Originally posted by rlaursen View Postfor those who have tested this.. do you feel a big difference in speed? if so, which patch are you running? If its worth it im sure we can get lifeforce to make an updated rom that includes this patch.
you have 3 to choose from
I think 696 and 816 work ok without to much heat have not tried highest one , probably work well in cooler climates.
JustMe
Originally posted by JustMe View Posttry the middle one i guess I haven't done enough testing.
JustMe
Originally posted by eugene2878 View PostCan i flash my box with beelink m8 firmware?
Square one FW dos not match round one FW!
If you do so, it will brick your device...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by rlaursen View Postim still trying to understand what the benefit of this is.. i mean yeah it raises the minimum clock but the cpu raises the clock speed on its own based on load. Say you run an app that pushes the cpu to the max 1992mhz.. the time it takes to go from 92mhz to 1992mhz and 816mhz to 1992mhz is probably fractions of a second isn't it? But thats not even realistic because 92mhz would be if it was completely idle.. im sure the clock speed goes up over 500mhz or whatever once you start navigating through the menus. To me its not worth the risk of wearing out and shortening the lifespan of your box by running it hotter 24/7. Even Antutu isn't showing better performance numbers according to some posts I read on here.
Check 1300min, you will see how smooth the Launcher works all the time...
This is the minimum CPU speed we are talking about not the Max... its not Overclocking the CPU hence there is no benefit for Antutu scores...
Antutu Scores Goes due to increased Heath after every run... Checked my Lg G2 ,cpu not going under 500mhz!
Originally posted by Zahir View PostFirst off, warm thanks to Bob for going the extra (3!) miles for us.
I tried the middle speed patch on Lifeforce and saw an improvement in menu lag -- but my Ethernet speed dropped by 50 per cent...
I have tried edit the boot.img with deetoolsgui but had a boot loop
Lifeforce edited the tcp buffer in init.rc
So yes using this patch on his ROM will reset the tcp buffers back to stock.
Tell you what. If Lifeforce doesn't patch his ROM after a few days, I will do it.
There are currently 3297 users online. 6 members and 3291 guests.
