Lifeforce ROM - Firmware for the M8 Tomato
you guys make me druel over the speeds .PBugs are Sons of Glitches!
JustMe
Thank You
Originally posted by Lifeforce View PostAnd then once more
I did a firmware, because i really need the paid apps. (Full firmware)
http://www.220volt.hu/temp/upload/pl..._Lifeforce.zip
- deodexed
- fixed a bug that not download paid apps (unfortunately, only a trick but it works)
- Google apps update
- root (su running as a daemon)
- Added init.d support
- LED problem fixed (Based on this Acemax)
- Fixed Wifi problems with 5G
- TCP buffer size increased
- Very unnecessary files removed (Chinese game)
I did not want to implement major changes (next time), people love to factory state.
Sorry my bad english
Originally posted by NoSkillz View PostXbmc is set to 1080 by default and does not auto detect tv resolution. Video will not display properly on any tv with resolution lower then 1080
5gz wifi is not showing much of an improvement on my unit. Ethernet speeds improved drastically !!!
this is a problem with just xbmc isnt it? I doubt the firmware has anything to do with it. Have you tried installing the latest stock version of xbmc to see if it changes?
Originally posted by antoniovidaljr View PostI wonder if we can use this CPU Control Patcher made for the S82 and s89?
http://www.freaktab.com/showthread.p...ontrol-patcher
However, I bet I can make one for you all that will work. I just need to know which STOCK ROM you prefer me to make it from. I wont make it from any custom ROM since I don't know what else it is doing.
- deodexed
This is the best firmware at the moment ...
Originally posted by Finless View PostIt's custom and I wont mess with it sorry... I really have no idea what was changed. Stock I can deal with better. BUT... even then since all this patch does is flash boot.img it may not matter... then again if he made changes to boot.img then you may loose functionality of his custom ROM. I am not going to pull apart that ROM and spend the time looking... Sorry. I don't have time to pull apart ROMs all the time.
Cpu Load ; 816 mhz
All 4 cores are active and Governor; interactive
Antutu score 23881!!!! runned 2 times without any trouble
Launcher is much much better now...
Thanks again for all your help and support
update; I've got no Audio hmmLast edited by TMx; 05-19-2014, 02:53.
Originally posted by TMx View PostNo worries Bob I've tried your zip update and It worked
Cpu Load ; 816 mhz
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by Zahir View PostWhy are we so excited about exchanging audio for a speed burst?
exciting part is to be able to use all 4 cores all the time @1.3ghz min freq. instead of 96mhz ...
p.s its not doing any overclocking but antutu score is 24177 if anyone interested
I see
Originally posted by TMx View Postthis mod for s89 Vega not compatible with m8 square...
There are currently 2326 users online. 5 members and 2321 guests.
