Lifeforce ROM - Firmware for the M8 Tomato
Originally posted by Finless View PostLifeforce edited the tcp buffer in init.rc
So yes using this patch on his ROM will reset the tcp buffers back to stock.
Tell you what. If Lifeforce doesn't patch his ROM after a few days, I will do it.
Its time to learn this stuff Can we do this stuff with Windows 7 or Linux is essential ?
I use Linux for editing boot.img
So yes you need Linux.
Get VirtualBox and install Ubuntu in a VM under windows 7.
New official? firmware
Found new firmware at http://androidpc.es/blog/2014/05/20/...x-m8-16052014/
Kernelversion 3.10.33
Fri May 16 15:06:57
Build number
KOT49H.20140516 testkeys
First impressions:
5G working
blinking light fixed
Paid apps can be downloaded
Still XBMC Gotham RC
WiFi seems be worse than the Lifeforce version though.
DownloadLast edited by handroid; 05-20-2014, 21:57.
Originally posted by handroid View PostFound new firmware at http://androidpc.es/blog/2014/05/20/...x-m8-16052014/
Kernelversion 3.10.23
Fri May 16 15:06:57
Build number
First impressions:
5G working
Download
Is anyone had tested it. If yes I will publish it on the first post.
to handroid !
Fri May 16 15:06:57
Build number
First impressions:
5G working
Download
signature verification issue.
resolved with this thread: http://www.freaktab.com/showthread.p...rmware-to-loadLast edited by rm65453; 05-22-2014, 03:38.
New one
Size of Acemax is different from the one that handroid show us.Here is the new one :
20140516 SW
http://www.mediafire.com/download/cb...AX_M8_0516.zip
I have tested handroid's one and original KK launcher had been added, but I had some probleme with Titanium Backup.
Will trie ACEMAX this evening.
Originally posted by MarcM View PostSize of Acemax is different from the one that handroid show us.Here is the new one :
20140516 SW
so what does this fix or add in this firmware and why is it better than life Forces's?Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postso what does this fix or add in this firmware and why is it better than life Forces's?
you will find the answer...RK3288 Devices
- Overview BOX (LINK !)
Thanks for all your hard work getting this box and others working at their prime.
Would you be able to patch Lifeforce's rom so we can patch your CPU Control Patcher?
Sorry, taken away from me the test device.
Soon I correct firmware.
Bob: thank you for your CPU patch.
If you also have problems installing the paid apps, in the services.jar file must be off the asec security.
Mount or permissions problem.
Several times I looked, but I could not find the error. (I did not have more time to deal with it)
Sorry my bad english
There are currently 2321 users online. 5 members and 2316 guests.
