NEW!! pureXbmc V2 - New firmware for CX-921a / EXOON Power Pro 2013
    pureXbmc V2.1 - full working Jelly Bean 4.2.2. Rom - perhaps the last JB Rom ever
    This is my new custom rom for xbmc media center usage on CX-921a RTL8188 wifi TV-BOX (no t-chip override at the moment, help is welcome!). Kernel build from source with new HDMI driver and real Rec. 709 color support (16-235). As user told this rom works perfect on CX-818b. Boxes like UT1 and K-R42 V1 with RTL8188 wifi should work two, please test.
    It's a really freaking fast 1080p full JB Rom and plays 20 GB MKV 1080p files over SMB lan inside my mod of Flumpters Beyond XBMC absolutely smooth with dolby/dts passthrough (haven´t tested bigger files cause i haven´t any).
    Features
    - 24 Bit HDMI Output with real REC.709 16-235 color support!
    - pureXbmc with dolby/dts passthrough
    - 1080p 24fps/25fps support!
    - rom is rooted and should support init.d scripts.
    - a lot of 1080p kernels!
    - Kernel supports a lot of file systems, like ISO, UDF, HFS, NTFS, FAT32, NFS...
    - new fast responding IR driver for stock remote!
    - modded launcher with Auto hide system bar option, performance settings, terminal and app background image
    - 2GB, 4GB, 6GB, 8GB, 10GB, 14GB parameter files
    - Antutu Score 21146 (1080p, 1800 CPU, 600h GPU, 800 DDR )
    Apps i put inside:
    BSPlayer FREE ( SMB support, Dolby/DTS Support ), Root Explorer, very cool Total Commander file explorer, Reboot (thanks to Petrus), Terminal, YouTube, SuperSu and pureXbmc (mod of Flumpsters Beyond XBMC Beta 3.4, THANKS!).
    Thanks to Radxa, Bob, d33, Flumpster, Wasser, Petrus, Lewy, phjanderson, MINIX and all the cool people at Freaktab.com! Thanks to mo123 for the info about Radxa sources. Thanks to Christian Ghisler for Total Commander
    04/08/2014
    Updated!! V2.1 with latest Google Apps!
    Kernel V27 with latest stock remote support inside!
    pureXbmc V2.1 1080p JB 4.2.2 Rom:
    Working sleep and Led turns off.
    Added new resolutions. Kernel now supports:
    1920x1080 at 60, 50, 30, 25, 24 Hz
    1280x720 at 60, 50, 30, 25, 24 Hz
    720x576 at 50 Hz
    720x480 at 60 Hz
    640x480 at 60 Hz
    Kernel doubles the framerate at 24/25Hz if your Monitor supports.
    24/25 will be displayed at 48/50. No sluggish mouse movement anymore at 24p!
    Best viewing experience in XBMC with 60/50 Hz.
    Kernel has HDMI-CEC support.
    Support for more filesystems.
    Please test and report.
    walter77
    Use it at your own risk!
    Donations are welcome and will be shared with other devs:
    DONATIONS
    CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
    Originally posted by walter77 View Post
    pureXbmc V2 - full working JB 4.2.2. Rom - perhaps the last JB Rom ever
    Your Rom look amazing!! by the way does support AP6210 Wifi? thanks
    -Chromecast with Google TV
    - Android Q Android 10
      Thanks! For which device you need AP6210?
      DONATIONS
        Hi, I tried on my mk908ii looks amazing but I too need the ap6210 wifi. I also have a cx919 which would need the same so................if you could include ap6210 support in your kernels I for one would be a very happy boy..................
        Cheers,
        Vec
          Yeah please! I'm on kitkat Rom right now, but if you include ap6210 WIFI support, I
          definitely jump on it...
            Just a short 1080p test kernel for ap6210 wifi. No bluetooth at the moment.
            Please test and report on which devices wifi will work.
            DONATIONS
              http://www.pure-xbmc.com/ap6210_kern...00h_ddr720.zip
              Just tried on my mk908ii tv stick wifi works good thank you very much !!!!!
              cheers,
              Vec
                Really amazing ROM !
                Only one problem... Whenever I put it to sleep it wakes up after 3-4 seconds... The LED doesn't turn
                off, too.
                I bought mine from here : http://www.efox-shop.com/cx-818b-and...mwifi-g-290778
                I know the name says 818B , but it has same specs as 921. Wifi works, too.
                No-Frills shows min 1.2 GHz and max 1.6 Ghz.. are these standard settings or did it set them wrong ?
                  off, too.
                  I know about the sleep problem. It's the first point on my list i want to fix.
                  Yes, the lower speed range is set to 1.2 but i can release a kernel pack with lower clock speeds, perhaps with fixed led and working sleep.
                  On my device a very stable kernel is 1.7, 600, 720. There are more kernels inside the kernel pack. You could try stock, 600, 720. This kernel has the original CPU speed with lower speed 312.
                  And you can just flash only the kernel on top of your rom so you can test which works best with your device. After flashing new kernel check speed with No-Frills.
                  DONATIONS
                    Thanks for this Walter
                    I haven't tried it yet but looking forward to it.
                    Anyone know if there is a working KITKAT rom for CX-921?
                      You can try UT1 KitKat roms.
                      DONATIONS
                        thanks man
                        I sent you a PM as well
                          Kernel config?
                          pureXbmc V2 - full working Jelly Bean 4.2.2. Rom - perhaps the last JB Rom ever
                          Features
                          - HDMI Output with real REC.709 16-235 color support!
                          - a lot of 720p and 1080p kernels, choose proper boot.img!
                          - two different kernels, one with support of hdmi output and one with hdmi/analog output.
                          If you don´t need analog output, you should use kernel with only hdmi output, cause it´s better supports 24p/25p.
                          - Kernel supports a lot of file systems, like ISO, UDF, NTFS, FAT32, NFS...
                          - 2GB, 4GB, 6GB, 8GB parameter files
                          Apps i put inside:
                          Thanks to Radxa, Bob, d33, Flumpster, Petrus, Lewy, phjanderson, MINIX and all the cool people at Freaktab.com!!Thanks to mo123 for the info about Radxa sources. Thanks to Christian Ghisler for Total Commander!
                          pureXbmc V2 JB Rom:
                          1080p Kernels
                          720p Kernels
                          Do you mind sharing your kernel config file? My cx921 doesn't recognize the ethernet for some reason...
                            Remote don't work
                            After installing the firmware 4 times( I had problems to choose the correct "parameter" file and finally works with the parameter4gb), I got everything working except the remote control.
                            Has this happened to anyone else?
                            The remote works fine with the original rom. to make a test, I flashed the "Kikat Android 4.4.2 wasser firmware for CX921b" and the remote works too. (but not wifi and ethernet).
                            Anyone know to fix it.
                            The board of my tvbox:
                            Thanks in advance
                              [ATTACH=CONFIG]6519[/ATTACH]
                              Thanks in advance
                              Thanks for your feedback. My Board is CX-921 Ver1.1 2013/05/07. Seems that you have new ir driver. I will look for IR code on my CX921b.
                              Just installed pureXbmc V2 on my CX-921b. Stock remote works perfect and has the same user code like CX-921a. I could upload two debug kernels for identifying your user code and scan data if you would like to spend 15 minutes?
                              DONATIONS
