thanks... downloading right now and hopefully will be able to test it tomorrow.
NEW!! pureXbmc V2 - New firmware for CX-921a / EXOON Power Pro 2013
Originally posted by rebootix View PostI flashed the kernel which was inside the package by default.
Unfortunately sleep doesn't work anymore :/ After I restarted the Box today
the same issues happened again. Screen goes off and after 5 seconds on again.
Maybe it is a app which is blocking the box from going to sleep...
Walter77
Sent from my iPhone using TapatalkDonations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
Originally posted by Emeisi View PostGreat news.
thanks.Donations are welcome and will be shared with other devs:
DONATIONS
Here it is:
Newest Kernel V23:
kernel_cx921a_1080p_walter77_v23_LCD1_cpu1608_ddr7 20_gpu600h_vsync.zip
Added new resolutions. Kernel now supports:
1920x1080 at 60, 50, 30, 25, 24 Hz
1280x720 at 60, 50, 30, 25, 24 Hz
720x576 at 50 Hz
720x480 at 60 Hz
640x480 at 60 Hz
Kernel doubles the framerate at 24/25Hz if your Monitor supports.
24/25 will be displayed at 48/50. No sluggish mouse movement anymore at 24p!
Best viewing experience in XBMC with 60/50 Hz.
Kernel has HDMI-CEC support.
Please test and report if it works.
As always, use at your own risk.
walter77Last edited by walter77; 04 July 2014, 23:39.Donations are welcome and will be shared with other devs:
DONATIONS
Newest Kernel V23:
First post updated with new kernel V23.Donations are welcome and will be shared with other devs:
DONATIONS
Ethernet not working
Walter77,
Thanks for all the time and work you put into your roms. I tried your rom on my cs918 and it boots up fine, except there is no ethernet. Is it possible to get ethernet working on this box, because I really like this rom and its the only one that has REC.709 16-235 color support. My board revision is LS_X6_V12 and it has the Realtek 8152B chip for lan. I don't care about wifi or bluetooth.
specs of my board
CPU: Rockchip RK3188-T
LAN: Realtek 8152B
WIFI: Realtek MT5931SA
Bluetooth: Realtek MT6622N
Audio: Rockchip RK1000-S
HDMI: ITE IT66121FN
Power Management: Active 8864QM
USB: SMSC USX2064AEZG
Memory: NANYA NT5CB512M8CN-CG
NAND Flash: Micron 29F64G08CBABA
specs of my board
LAN: Realtek 8152B
HDMI: ITE IT66121FN
Walter77
Gesendet von meinem iPad mit Tapatalk HDDonations are welcome and will be shared with other devs:
DONATIONS
cool thanks. Take your time, no rush.
Originally posted by walter77 View PostAt the moment my kernel has no RK3188-T override, so i think it will be too slow for 1080p playback. But i will have have look at your specs and try to build a kernel for your device.
Walter77
hi Walter77 . i have a CX-921 tv Box . i am installed a lot of rom and any works with stock remote control . the las rom Installed is PureXbmc and Work fine i am like come with a Lot Of Add on . Thanks for all . I am read the first and second page of this trhead and the user Emeisi have same problems . i am installled kernels that you make for him and dont work remote dont workhehehehe . i am installed the Debug Kernels for see and is aonther number in the comand line . here my data and hope that you help me . THANKS for all hard work that you make . sorry for my english is very bad . i am test again with my tv box , i am put a kernel of NEO x 7 and remote work fine but the wifi dont work , with your ROm Wifi work fine but remote control Not
. this link is the kernel of NEO X7 maybe you can check jejejeje . thanks for your time . https://mega.co.nz/#!FswR3L7Q!4HaP7m...sgp7CP4-ZV_eJM this is a Kernel ne x control remote work fine but not wifi .
81.803597 init: unstracked pid 1337 exited
83.347047 U=0X807f
this number have with kernel debug
ROCKCHIP CX 921
SYSTEM (Android 4.2.2)
Model: CX-921
Manufacturer: rockchip
Device: rk31sdk
Product: rk31sdk
Brand: rk31sdk
Android Version: 4.2.2 (Jelly Bean)
API Level: 17
Build ID: JDQ39
Fingerprint: rk31sdk/rk31sdk/rk31sdk:4.2.2/JDQ39/eng.root.20130913.182436:eng/test-keys
DISPLAY (1280x720)
Refresh Rate: 60 Hz
Default Orientation: Portrait
Physical Size: 9.16" (23.26 cm)
Logical Size: Large
Density: 160 dpi (Medium)
Pixels Per Inch: X: 160.42; Y: 160.16
PROCESSOR (ARMv7)
Processor: ARMv7 Processor rev 0 (v7l)
Cores: 4
Max Frequency: 1608 Mhz
Instruction Sets: armeabi-v7a, armeabi
SIMD Instructions: NEON
[IMG]
[/IMG]
Originally posted by tecnor View PostHi Walter can you help me with my Tv Box Please ? thanks for your time . Regards
Walter77
DONATIONS
Originally posted by tecnor View PostOk , thank so much Walter77 . Regards
kernel_scandata_807f.zip
Please follow the guide in post #20.
Walter77Donations are welcome and will be shared with other devs:
DONATIONS
Sorry but i will leave FREAKTAB in a few days!
Hey guys, i will leave FREAKTAB in a few days cause i will have no time for this freaking hobby anymore.
All the best
DONATIONS
There are currently 1733 users online. 0 members and 1733 guests.
