NEW!! pureXbmc V2 - New firmware for CX-921a / EXOON Power Pro 2013
HI walter77 i am make code for all key pls check . thanks a lot for your time .
power d=18e7
fast rewind = d=3cc3
fast forward ffwd = d=f20d
stop = d=d42b
play pause = d=58a7
back d=2fd
home d=609f
cursor d=20df
volume down d=28d7
volume up d=8f7
mute d=10ef
TV d=6a95
VOD d=ea15
APP d=f807
SETUP d=da25
KEY CHINESE DOWN OF KEY BACK d=e817
KEY OK d=aa55
KEY UP d=629d
KEY DOWN d=6897
KEY LEFT d=e21d
KEY RIGTH d=a857
KEY CHINNESE e d=827d
KEY CHINENSE x d=d22d
1 d=2ad5
2 d=12ed
3 d=e01f
4 d=af5
5 d=48b7
6 d=8877
7 d=32cd
8 d=708f
9 d=b04f
0 d=30cf
I tried your newest kernel and it is working perfectly !
I don't have to power it off completely after using it everytime
I'm sorry to hear that you want to quit doing this great work. It is really amazing so far.
I think more and more people will need custom keymap kernels for their remotes, so I wanted
to ask if you could write a tutorial on how to add a custom keymap to the kernel, so that everyone
could do it. I own a Mele F10 Pro which has a IR-button for power. At the moment I have to power off the
TV-Box with stock remote but if you would write a tutorial I could add the F10's power button to the kernel
and power it off using only one remote.
Thanks again for your amazing work !!
Great to hear that it is working. I don't want to quit completely but i'm a teamplayer and it's quite frustrating doing the whole job alone. I thought it would be easy to do some things together with other people here at freaktab, but it's quite difficult to get infos from other "devs".
Adding a remote is quite simple, if you know how ;-)
I asked a lot of people but no one told me. So i learned it and now it's quite easy. As you can read you need two different kernels to get the usercode for a new remote. With this code you compile a new kernel to get the scancode for each key on your remote. Now you have to add this code to your kernel source and that's it.
As i wrote in another thread, i still will try to remove bugs from my kernel, but the time for JB has come and xbmc works quite perfect on cx921 for my needs and this was my intention to build up a rom, just for me and for people who have the same needs.
Walter77
Gesendet von meinem iPad mit Tapatalk HD
Donations are welcome and will be shared with other devs:
Sounds simple, but everyone would need the kernel source and some information on which files
to modiy , or am i wrong ? I think no one would be able to create his own kernel with all these
great features inside
power d=18e7
stop = d=d42b
play pause = d=58a7
back d=2fd
home d=609f
cursor d=20df
volume down d=28d7
volume up d=8f7
mute d=10ef
TV d=6a95
VOD d=ea15
APP d=f807
SETUP d=da25
KEY OK d=aa55
KEY UP d=629d
KEY DOWN d=6897
KEY LEFT d=e21d
KEY RIGTH d=a857
1 d=2ad5
2 d=12ed
3 d=e01f
4 d=af5
5 d=48b7
6 d=8877
7 d=32cd
8 d=708f
9 d=b04f
0 d=30cf
I haven't test it cause i'm not at home, but it should work ;-)
I also have defined this four buttons in this kernel:
fast rewind - key 242
fast forward - key 241
stop - key 166
play pause - key 164
You need to define these buttons inside of "rkxx-remotectl.kl" too.
Possible functions are inside Generic.kl.
Both files are inside system/usr/keylayout
For stop you have to add "key 166 MEDIA_STOP" to rkxx-remotectl.kl
But you can reassign any key you want.
Please report back and i you have a nice working kl files for your remote, please share it in this thread.
Walter77
I think my kernel source for cx921a box is quite perfect, i spend a lot of time on it, but i will share it with anybody who can optimize it. Do you know how github works?
Walter77
I am test the kernel compiled for me and Works all great !!!! Thanks Friend for your time and work .
With a little bit of luck i will find you and invite you a some beers hehehehe . you have some paypal acount for make a Little donation for your time ?
Thanks Again Walter77 .
Regards
Tecnor
Hey Tecnor, nice to hear that it works for you! You don't have to pay me for that, it's time to travel to nicaragua and take some beers with you :-)
Until that, have a lot of fun with your box!
Walter77
Hi Walter77 Thanks a Lot i am Waiting for Beers , all Works perfect only power Off not power Off only Sleep heheheheeh But is Ok .
Regards .
tecnor
Hey tecnor, you can power off with reboot apk. But you have to remove power cord and plug it back to turn on device. Hardware don't support something like standby, but sleep mode does quite the same. With this kernel i allow lowest ddr, gpu and cpu speed in sleep mode.
Kernel v24 will also work on all other cx921 boxes!!
If you will ever be in hamburg, let me know ;-)
Walter77
Hi Walter,
Realy perfect rom, I use it already 3 weeks, stable and fast. But need help with remote controller (work only back key as a home key), please help me.
Hi Walter,
Realy perfect rom, I use it already 3 weeks, stable and fast. But need help with remote controller (work only back key as a home key), please help me.[ATTACH=CONFIG]7230[/ATTACH]
First i need the usercode of your remote. After that i will compile a kernel for the scan codes of your remote buttons, but it's all mentioned in the post above.
Walter77
