KeyTest.zip
Walter77
static struct rkxx_remote_key_table remote_key_table_testremote[] = { {0xf0 , KEY_PLAYPAUSE}, {0xfa , KEY_HOME}, {0xc1 , KEY_YELLOW}, {0xa3 , KEY_RED}, {0xb5 , KEY_VIDEO_NEXT}, };
{ .usercode = 0xe32, .nbuttons = 5, .key_table = &remote_key_table_testremote[0], },
static int remotectl_init(void) { printk(KERN_INFO "++++++++remotectl_init\n"); // Read in file from root here and populate // struct with data from file<---- return platform_driver_register(&remotectl_device_driver); }
case RMC_USERCODE: { ddata->scanData <<= 1; ddata->count ++; if ((TIME_BIT1_MIN < ddata->period) && (ddata->period < TIME_BIT1_MAX)){ ddata->scanData |= 0x01; } if (ddata->count == 0x10){//16 bit user code // Only print user code if value in local file // is set to 1 (eg. if(read_usercode)... ) // printk("u=0x%x\n",((ddata->scanData)&0xFFFF)); if (remotectl_keybdNum_lookup(ddata)){ ddata->state = RMC_GETDATA; ddata->scanData = 0; ddata->count = 0; }else{ //user code error ddata->state = RMC_PRELOAD; } } }
case RMC_GETDATA: { ddata->count ++; ddata->scanData <<= 1; if ((TIME_BIT1_MIN < ddata->period) && (ddata->period < TIME_BIT1_MAX)){ ddata->scanData |= 0x01; } if (ddata->count == 0x10){ // The same here : only print button codes if value // in local file is set to 1 (eg. if(read_buttoncode) ...) // printk(KERN_ERR "d=%x\n",(ddata->scanData&0xFFFF)); ...
read_usercode=1 read_buttoncode=1
num_buttons = 3 {0xf0,KEY_POWER} {0xb2,KEY_HOME} {0xa9,KEY_MUTE}
static void read_custom_remote(){ // Open rk_custom.remote from sdcard root FILE *rk_remote = fopen("/sdcard/rk_custom.remote","r"); // If file could not be opened if(rk_remote != NULL){ // Every line from file will be stored in this buffer char buffer[32]; // Debug variables if(fgets(buffer,32,rk_remote) != NULL){ if(buffer[15] == '1') print_usercode = 1; } if(fgets(buffer,32,rk_remote) != NULL){ if(buffer[17] == '1') print_buttoncode = 1; } // Read usercode from file if(fgets(buffer,32,rk_remote) != NULL){ char usercode_string[] = { buffer[9] , buffer[10], buffer[11], buffer[12] }; int usercode = atoi(usercode_string); remotectl_button[2].usercode = usercode; } // Check if read_table is = 1 int read_table = 0; if(fgets(buffer,32,rk_remote) != NULL){ if(buffer[11] == '1') read_table = 1; } // Read in button mapping from file // only if file says so if(read_table){ int table_index = 0; int button_count = 0; //While the next line is present while(fgets(buffer,32,rk_remote) != NULL){ // Get scancode from file char scancode_string[] = {buffer[1] , buffer[2], buffer[3]}; int scancode = atoi(scancode_string); // Get keycode from file char keycode_string[] = {buffer[5] , buffer[6] , buffer[7]}; int keycode = atoi(keycode_string); // Store scan- and keycode in custom remotes array remote_key_table_custom[table_index].scanCode = scancode; remote_key_table_custom[table_index].keyCode = keycode; table_index++; button_count++; } // Set the remotes number of buttons remotectl_button[2].nbuttons = button_count; } } else { printk("ERROR : /sdcard/rk_custom.remote does not exist !"); } fclose(rk_remote); }
static int remotectl_init(void) { printk(KERN_INFO "++++++++remotectl_init\n"); read_custom_remote(); return platform_driver_register(&remotectl_device_driver); }
{ .usercode = 0, .nbuttons = 0, .key_table = &remote_key_table_custom[0], },
int print_usercode = 0; int print_buttoncode = 0; static struct rkxx_remote_key_table remote_key_table_custom[64] = { };
print_usercode=1 print_buttoncode=1 usercode=0000 read_table=0 {255,136} {033,001} {123,029}
// Only print usercode if local file says so if(print_usercode) printk("u=0x%x\n",((ddata->scanData)&0xFFFF));
// Only print buttoncode if local file says so if(print_buttoncode) printk(KERN_ERR "d=%x\n",(ddata->scanData&0xFFFF))
<6>[ 626.073371] qtaguid: ctrl_counterset(s 1 10049): insufficient priv from pid=424 tgid=363 uid=1000 <6>[ 626.862503] qtaguid: ctrl_counterset(s 0 10052): insufficient priv from pid=424 tgid=363 uid=1000 <6>[ 632.196747] qtaguid: ctrl_counterset(s 1 10058): insufficient priv from pid=424 tgid=363 uid=1000 <6>[ 632.981211] qtaguid: ctrl_counterset(s 0 10049): insufficient priv from pid=424 tgid=363 uid=1000 <6>[ 749.568440] qtaguid: ctrl_counterset(s 1 10052): insufficient priv from pid=424 tgid=363 uid=1000 <6>[ 750.007843] qtaguid: ctrl_counterset(s 0 10058): insufficient priv from pid=424 tgid=363 uid=1000 <4>[ 1177.529646] RTL871X: set group key to hw: alg:4(WEP40-1 WEP104-5 TKIP-2 AES-4) keyid:2 <4>[ 1177.529822] RTL871X: send eapol packet <6>[ 1660.761962] qtaguid: ctrl_counterset(s 0 10052): insufficient priv from pid=424 tgid=363 uid=1000 <4>[ 1662.612117] enter func vmac_open... <4>[ 1663.615875] power on phy <6>[ 1664.674877] vmac_mii_bus: probed <6>[ 1664.676299] rk29 vmac rk29 vmac.0: PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1) <6>[ 1664.678641] ADDRCONF(NETDEV_UP): eth0: link is not ready <6>[ 1666.668371] PHY: 0:00 - Link is Down <4>[ 1669.440800] enter func vmac_close... <6>[ 1672.773446] qtaguid: ctrl_counterset(s 1 10052): insufficient priv from pid=424 tgid=363 uid=1000
<6>[ 171.977923] qtaguid: ctrl_counterset(s 1 10010): insufficient priv from pid=422 tgid=364 uid=1000 <6>[ 173.321278] qtaguid: ctrl_counterset(s 0 10008): insufficient priv from pid=422 tgid=364 uid=1000 <6>[ 254.512217] qtaguid: ctrl_counterset(s 0 10010): insufficient priv from pid=422 tgid=364 uid=1000 <4>[ 256.329251] enter func vmac_open... <4>[ 256.329340] !!!!!!!!!!11111111111111!!!! <4>[ 256.329428] power on phy <4>[ 257.368955] !!!!!!!!!!222222222222222!!!! <4>[ 257.369117] Read the Ethernet MAC address from IDB:00:00:00:00:00:00 <4>[ 257.369227] eth_mac_from_RANDOM***********:EE:E9:E0:B3:C7:0 <4>[ 257.369296] !!!!!!!!!!33333333333333!!!! <4>[ 257.379899] !!!!!!!!!!44444444444444444!!!! <4>[ 257.379959] !!!!!!!!!!55555555555555!!!! <6>[ 257.402318] vmac_mii_bus: probed <4>[ 257.402445] !!!!!!!!!!777777777777777777!!!! <6>[ 257.402483] rk29 vmac rk29 vmac.0: PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1) <4>[ 257.402540] !!!!!!!!!!8888888888888888888!!!! <6>[ 257.403572] ADDRCONF(NETDEV_UP): eth0: link is not ready <6>[ 259.399296] PHY: 0:00 - Link is Down <4>[ 263.345298] enter func vmac_close... <6>[ 266.613032] qtaguid: ctrl_counterset(s 1 10010): insufficie
static struct rkxx_remote_key_table remote_key_table_mele[] = { {0xEA, KEY_POWER}, };
{ .usercode = 0xf9, .nbuttons = 1, .key_table = &remote_key_table_mele[0], },
su
echo 1 > /proc/print_usercode
dmesg
u=yourusercode
echo 0 > /proc/print_usercode
echo yourusercode > /proc/remote_id
echo 1 > /proc/print_buttoncode
dmesg
d=yourbuttoncode
There are currently 2223 users online. 1 members and 2222 guests.
