Walter77
NEW!! pureXbmc V2 - New firmware for CX-921a / EXOON Power Pro 2013
Originally posted by huniak View Post
Walter77Donations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
Originally posted by walter77 View PostThis kernel was just for testing, if your remote is working with this kernel. So can you please check your buttons?
Walter77
power
menu (but function as a back)
back (but function as a home)
mute d=10ef
key up
key down
key left
key right
not working:
fast rewind
cursor
ok
home
volume up
volume down
tv button
camera button
Originally posted by huniak View Postok, what working:
power
mute d=10ef
key up
key down
key left
key right
not working:
fast rewind
cursor
ok
home
volume up
volume down
tv button
camera button
Here it is...
cx921a/kernel_cx921a_1080p_v25_LCD1_0x202.zip
Please give me each code for the corresponding button.
DONATIONS
Originally posted by walter77 View PostOK i will compile a kernel for your to get the codes...
Here it is...
Walter77
ok, buttons:
power d=b24d
cursor d=e21d
mute d=c23d
key left d=8f7
key up d=d02f
key right d=8877
key down d=708f
key menu (or settings?) d=a25d
home d=58a7
back d=42bd
volume up d=18e7
volume down d=e817
fast rewind next d=7887
fast rewind back d=f807
TV key d=ea15
Camera key? d=2ad5
Originally posted by huniak View Postok, buttons:
power d=b24d
cursor d=e21d
mute d=c23d
key left d=8f7
key up d=d02f
key right d=8877
key down d=708f
home d=58a7
back d=42bd
volume up d=18e7
volume down d=e817
TV key d=ea15
Camera key? d=2ad5Donations are welcome and will be shared with other devs:
DONATIONS
Originally posted by huniak View PostOk, thank you for your patienceDonations are welcome and will be shared with other devs:
DONATIONS
Originally posted by huniak View PostOk key d=b04f
Please test and report back.
DONATIONS
Cursor (arrow) - dont know how must this button work, fast rewind buttons and bottom two keys tv and camera , but this last two is not very important for me.
Thank you Walter
Thank you Walter
The cursor button is mapped as mouse switch, this button should work. The four other buttons have to be inserted into the rkxx-remotectl.kl file. Some posts ago i wrote how to do that.
Here is kernel v25b:
kernel_cx921a_1080p_v25b_LCD1_vsync_cpu1608h_gpu60 0h_ddr720.zip
DONATIONS
Hey Walter,
I digged through the radxa source and I think I found out how to add custom remotes + mapping tables.
I just wanted you to confirm on my theory
So i went into "/kernel/drivers/input/remotectl/" and there i found "rkxx_remotectl.c".
Inside this file i found some structs which define button mappings inside them. One struct
for each remote control, is that right ?
A little bit further down i found another struct "remotectl_button" which holds data on the defined
controls(the user code, number of buttons and a pointer to the controls mapping table struct).
So all I have to do is find out the usercode and every buttons code, create a mapping table struct
and put it inside the remotectl_button struct with its usercode, or am I missing something ?
If that is all i could try to write a litte program, that would make it easier to add custom remote
controls to the input driver.
Hope you can answer my question
Originally posted by huniak View PostOk, thank you for your patienceOriginally posted by rebootix View PostHey Walter,
that's completely right. At the moment, this is my actual configuration:
static struct rkxx_remote_key_table remote_key_table_cx921_v1_1[] = {
{0x2a, KEY_1},
{0x12, KEY_2},
{0xe0, KEY_3},
{0xa, KEY_4},
{0x48, KEY_5},
{0x88, KEY_6},
{0x32, KEY_7},
{0x70, KEY_8},
{0xb0, KEY_9},
{0x82, KEY_SPACE},
{0x30, KEY_0},
{0xd2, KEY_BACKSPACE},
{0xaa, KEY_REPLY},//ok = DPAD CENTER
{0x2, KEY_BACK},
{0x62, KEY_UP},
{0x68, KEY_DOWN},
{0xe2, KEY_LEFT},
{0xa8, KEY_RIGHT}, ////////
{0x60, KEY_HOME}, //home
{0x8, KEY_VOLUMEUP},
{0x28, KEY_VOLUMEDOWN},
{0x18, KEY_POWER}, //power off
{0x10, KEY_MUTE}, //mute
{0x20, KEY_MENU},
//media ctrl
{0x6a, KEY_RED},
{0xea, KEY_GREEN},
{0xb8, KEY_YELLOW},
{0xda, KEY_SEARCH}, //blue
{0xe8, 388},//mouse switch
static struct rkxx_remote_key_table remote_key_table_cx921_v1_2[] = {
{0x88, KEY_1},
{0x48, KEY_2},
{0xc8, KEY_3},
{0x28, KEY_4},
{0xa8, KEY_5},
{0x68, KEY_6},
{0xe8, KEY_7},
{0x18, KEY_8},
{0x98, KEY_9},
{0xb2, KEY_SPACE},
{0x8, KEY_0},
{0xd8, KEY_BACKSPACE},
{0xf8, KEY_REPLY},//ok = DPAD CENTER
{0xa0, KEY_BACK},
{0x0, KEY_UP},
{0x80, KEY_DOWN},
{0xc0, KEY_LEFT},
{0x40, KEY_RIGHT}, ////////
{0x2, KEY_HOME}, //home
{0x60, KEY_VOLUMEUP},
{0xd0, KEY_VOLUMEDOWN},
{0x50, KEY_POWER}, //power off
{0x30, KEY_MUTE}, //mute
{0x38, KEY_MENU},
//media ctrl
{0x70, KEY_RED},
{0x78, KEY_GREEN},
{0x32, KEY_YELLOW},
{0x22, KEY_SEARCH}, //blue
{0xe0, 388},//mouse switch
static struct rkxx_remote_key_table remote_key_table_cx921_v1_4[] = {
{0x2a, KEY_1},
{0x12, KEY_2},
{0xe0, KEY_3},
{0xa, KEY_4},
{0x48, KEY_5},
{0x88, KEY_6},
{0x32, KEY_7},
{0x70, KEY_8},
{0xb0, KEY_9},
{0x82, KEY_SPACE},
{0x30, KEY_0},
{0x2, KEY_BACK},
{0x62, KEY_UP},
{0x68, KEY_DOWN},
{0xe2, KEY_LEFT},
{0xe8, KEY_MENU},
//media ctrl
{0x6a, KEY_RED},
{0xea, KEY_GREEN},
{0xf8, KEY_YELLOW},
{0x20, 388},//mouse switch
{0x6a, KEY_VIDEO_NEXT},
{0x6a, KEY_VIDEO_PREV},
{0x58, KEY_PLAYPAUSE},
{0xd4, KEY_STOPCD},
static struct rkxx_remote_key_table remote_key_table_cx921_v1_5[] = {
{0xb0, KEY_REPLY},//ok = DPAD CENTER
{0x42, KEY_BACK},
{0xd0, KEY_UP},
{0x70, KEY_DOWN},
{0x8, KEY_LEFT},
{0x88, KEY_RIGHT}, ////////
{0x58, KEY_HOME}, //home
{0x18, KEY_VOLUMEUP},
{0xe8, KEY_VOLUMEDOWN},
{0xb2, KEY_POWER}, //power off
{0xc2, KEY_MUTE}, //mute
{0xa2, KEY_MENU},
{0xe2, 388},//mouse switch
//media ctrl
{0xea, KEY_RED},
{0x2a, KEY_SEARCH},
{0x78, KEY_VIDEO_NEXT},
{0xf8, KEY_VIDEO_PREV},
static struct rkxx_remote_key_table remote_key_table_meiyu_202[] = {
{0xB0, KEY_REPLY},//ok = DPAD CENTER
{0xA2, KEY_BACK},
{0xD0, KEY_UP},
{0x70, KEY_DOWN},
{0x08, KEY_LEFT},
{0x42, KEY_HOME}, //home
{0xA8, KEY_VOLUMEUP},
{0x38, KEY_VOLUMEDOWN},
{0xE2, KEY_SEARCH}, //search
{0xB2, KEY_POWER}, //power off
{0xC2, KEY_MUTE}, //mute
{0xC8, KEY_MENU},
//media ctrl
{0x78, 0x190}, //play pause
{0xF8, 0x191}, //pre
{0x02, 0x192}, //next
//pic
{0xB8, 183}, //rorate left
{0x58, 184}, //rorate right
{0x68, 185}, //zoom out
{0x98, 186}, //zoom in
//mouse switch
{0xf0,388},
//display switch
{0x82, 0x175},
static struct rkxx_remote_key_table remote_key_table_df[] = {
{0xf8, KEY_REPLY},
{0xc0, KEY_BACK},
{0xf0, KEY_UP},
{0xd8, KEY_DOWN},
{0xd0, KEY_LEFT},
{0xe8,KEY_RIGHT}, ////////
{0x90, KEY_VOLUMEDOWN},
{0x80, KEY_HOME}, //home
{0xe0, 183}, //rorate left
{0x10, 184}, //rorate right
{0x20, 185}, //zoom out
{0xa0, 186}, //zoom in
{0x70, KEY_MUTE}, //mute
{0x40, KEY_SEARCH}, //search
static struct rkxx_remote_key_table remote_key_table_sunchip_202[] = {
{0x60, KEY_HOME}, // home
{0x02, KEY_BACK}, // back
{0x20, KEY_MENU}, // menu
{0xAA, KEY_REPLY}, // ok
{0x62, KEY_UP},
{0x68, KEY_DOWN},
{0xE2, KEY_LEFT},
{0xA8, KEY_RIGHT},
{0x08, KEY_VOLUMEUP},
{0x18, KEY_POWER}, //power (RED)
{0x40, KEY_POWER}, //power (GREEN)
{0x6A, KEY_VOLUMEDOWN}, // function RED
{0xEA, KEY_VOLUMEDOWN}, // function GREEN
{0xF8, KEY_VOLUMEDOWN}, // function YELLOW
{0xDA, KEY_VOLUMEDOWN}, // function BLUE
{0x2A, 183}, // Digit 1
{0x12, 388}, // Digit 2
{0xE0, 184}, // Digit 3
{0x0A, 185}, // Digit 4
{0x48, KEY_VOLUMEDOWN}, // Digit 5
{0x88, 186}, // Digit 6
{0x32, KEY_VOLUMEDOWN}, // Digit 7
{0x70, KEY_VOLUMEDOWN}, // Digit 8
{0xB0, KEY_VOLUMEDOWN}, // Digit 9
{0x30, KEY_SEARCH}, // Digit 0
{0xD2, KEY_VOLUMEDOWN}, // Delete
{0xC0, 183}, // Signal source
{0x28, 184}, // Volume down (TOP)
{0x08, 184}, // Volume up (TOP)
{0xE8, KEY_SEARCH}, // search
extern suspend_state_t get_suspend_state(void);
static struct rkxx_remotectl_button remotectl_button[] =
.usercode = 0xff,
.nbuttons = 29,
.key_table = &remote_key_table_cx921_v1_1[0],
// .usercode = 0xff,
// .nbuttons = 13,
// .key_table = &remote_key_table_radxa[0],
.usercode = 0x12ee,
.nbuttons = 29,
.key_table = &remote_key_table_cx921_v1_2[0],
.usercode = 0x807f,
.nbuttons = 33,
.key_table = &remote_key_table_cx921_v1_4[0],
// .nbuttons = 22,
// .key_table = &remote_key_table_sunchip_202[0],
.usercode = 0x206,
.nbuttons = 22,
.key_table = &remote_key_table_meiyu_202[0],
.usercode = 0x12ee,
.nbuttons = 22,
.usercode = 0x202,
.nbuttons = 17,
.key_table = &remote_key_table_cx921_v1_5[0],
.usercode = 0xdf,
.nbuttons = 16,
.key_table = &remote_key_table_df[0],
A little program would be cool, cause it takes a lot of time to add a new remote ;-)
DONATIONS
Originally posted by rebootix View PostCool
Do you have a list with all the Key Names ? (eg. KEY_HOME etc.)
I want to include every possible Key so that everything can be mapped
It's inside this file:
kernel/include/linux/input.h
DONATIONS
There are currently 1710 users online. 0 members and 1710 guests.
