Arnova 10b G2 BETA TESTING THREAD - Finless Bob's "GingerComb" ROM Version 2.1 CWM
    BETA TESTING for the 10b G2 Capactive is over!
    BETA TEST 3 of the 10b G2 resisitive is still ongoing.
    I am closing this thread and will make new ones.
    The downloads are OFFline until I finish this work.
    Ok folks. With the success of my "Gingercomb" ROM for the 10G2, I am now releasing this same ROM for the
    Arnova 10b G2 Capacitive Screen
    Resistive is removed and needs more work. Sorry.
    Arnova 10b G2 Resisitive Screen.
    No need for a BETA test as these models are all pretty much the same excpet for the kernel and screen driver. So I hope new bugs do not show up but I kind of doubt it. My testing shows my scripts to make the ROM worked 100%.
    Below is my stock description for Gingercomb and the download links below that.
    _______________________________________
    2.1 is really my 2.0D with all of the fixes found to date and I have added Clockwork Mod. Now the testing of CWM was odd I must say. Most it worked for. Some had problems which I cannot repeat myself. It works for me 100%. Heck I can even flash 2.1 and restore 2.0 with no problems at all and visa versa.
    Remember though. If you backup say 2.0 and flash 2.1 and try to restore 2.0, YOU WILL be back on 2.0 if you do a full restore! This is because it writes boot.img and system.img BACK! THis is in fact how CWM is suppose to work folks! If you want to try a "advanced" restore and restore your data and setting you can try it. Do an advanced restore and ONLY restore data and cache. If it does not work well... thats the way it goes! CWM is never a 100% gaurentee when you try to restore from different ROMs.
    Now for those that dont want to use CWM.... Don't! It will not effect how the ROM works at all! Just on first boot after flash you will get the CWM menu. Select reboot now. DONE... you will never see CWM menu again unless you want to.
    Want to know more about what CWM is? Read this:
    http://www.addictivetips.com/mobile/...omplete-guide/
    Also in the new APP Injector package is Petrus' reboot app. Install this if you want to reboot into recovery from the OS. Other apps wont do it for reasons I have gone into before. It's how Arnova decided to remove support for recovery from the kernel.
    And more good news! I got permission from the maker of Button Savior! So that is now cooked into the ROM as a system app
    OK for those that do not know what 2.0 is and want to know before flashing 2.1 which again is 2.0 with fixes and CWM, please read this post:
    Now last tidbit. Again this does not support 3G sticks. I have explained why many times. I am using the latest Arnova 10 G2 "philly" kernel. This kernel has fixes in it that in my opinion are needed over what the old 10 G2 kernel had. BUT when Arnova made this kernel they killed 3G stick support. I have tried to make this 2.1 ROM using the old kernel but it has major problems with the honeycomb framework. So I will do my best to try more to get 3G sticks working but there is no gaurentee! Sorry but dont blame me for this. Email Arnova and tell them to fix the kernel.
    BETA TEST IS OVER
    Enjoy,
    Damo - Forum Moderator
    PLEASE CLICK THE DONATE LINK BELOW
    PS
    If you are having trouble with the above link when using Tapatalk than here is the email link for donations below
    https://www.paypal.com/cgi-bin/websc...=ZYCM4NZ4J6F3G
    Thank You
    Thank you Im downloading it now!!
      thanks guys
      Just sent a donation for the fund will download and flash my tablet when I get home from the tattoo shop,thanks for everything.y'all are the coolest.
      freaktab art developer if you like my work please buy me a pepsi
        Thank You
        </form>
          still touch screen off on the Arnova 10b G2 Resisitive Screen. gonna give it another go after the kids are asleep lol
            There are 2 links for download! Make sure you downloaded the resistive screen version!
            I tested it and on my capacitive 10G2 and the resistive screen version did not work so I know I used the right kernel and files!
            The ZIP file name you should have is:
            arnova10g2r_gingercomb_finless21cwm.zip
            If you have this file:
            arnova10g2c_gingercomb_finless21cwm.zip
            You downloaded the wrong ROM!
            ALSO did you READ the README! The screen, audio, etc "may" NOT WORK RIGHT until you reboot right after flashing the ROM. This means; in CWM select reboot.... THEN REBOOT AGAIN once the OS (desktop) loads. ONLY THEN will stuff work right...
              Ok tried it again and same. On the R download Touch is off on mine. Tried the readme as well. I can get in but cant do much like calibration is off or something. If i hit a icon on screen like settings i get nothing so i tried the back icon on the bottom left and nothing there. Now if i hit up where google is it clicks the back button. Tryed rotating and it seems that nothing can be clicked, then upside down i get clock options if i click in the middle. Basicly touch is off calibration it seems .
                CRAP.... I think your right! I forgot.... I have to put the screen calibration wizard back in this ROM to start...
                Sheesh... I am an idiot!
                Sorry hang tight... I will recook the resisitive model and habve a good look at what is needed here.
                  no worries your doing great!!
                    I hate to tell you this but I do not think I will be able to get this Cube ROM working on a resistive screen Arnova! The calibration wizard was compiled under a different SDK and thus force closes. It wont run.
                    I will have a look more at this and see if maybe Miklaus can make the calibration wizard work. BUT... seeing what I am seeing now. I think the resistive folks are going to be out of luck for a 2.1 ROM!
                    Sorry....
                      Thats ok lol I thought this day may come lol
                        This is the third time that I install your programs, primarily the 1.4 then 1.5 and now 2.1.
                        Each time it was a success, it works well, thank you very very much
                        bravo Finless and your team
                          sad tablet
                          Got home late last night, got up this morning excited to flash my tablet only to see 10bg2 resistive was removed due to problems. But im sure if there's a fix Bob will figure it out.so if you do Bob just holler and I'll be more than happy to test it out
                          Sent from my 10bg2 resistive finless 1.5
                            I am working on it now kind of. Arnova had a screen calibration wizard that started up automatically. That wizard will not work on this ROM. However I have CM7 that also has a wizard and I am hoping that will work. If that does not work I am hoping I can find one that will.
                            So you 2 guys will have to totally be my testers as I cannot test this in any way.
                              Just let me know Bob, I'm sure you'll figure something out.we'll test till we're blue in the face
