PLEASE follow these instructions to the letter.
First go get ES FIle explorer and set it up with these settings:
a) go into "file setting" and turn on show hidden files. Back up one level.
b) scroll down and turn on up to root.
c) Scroll down and turn on root explorer
d) below that turn on mount system as RW
OK download this file:
http://video.freaktab.com/?subpath=f...name=calib.zip
Unzip it and put TSCalibration.apk on your SDcard.
Now lets go to work
1) In ES File explorer go to /system/app.
2) Rename wizard.apk to wizard.old
3) Rename TSCalibration.apk to TSCalibration.old
4) Copy the TSCalibration.apk from your SDcard into /system/app
5) Once it is copied, hold your finger on TSCalibration.apk until you get a pop up. In the pop up scroll down and select properites.
6) Click the change box to change permissions. Make sure all 9 boxes are checked and click OK.
7) Now this is important! We must wipe the system. Go into settings, privacy, and do a factory reset and erase all data (dont select erase your sdcard!)
Now the system will reboot clean. You should get the TSCalibration show up and not see the desktop or lockscreen on first boot. Calibrate your screen. When done it will go to the desktop! BUT.... the screen may still be screwed up. Either way, You must reboot now. See if you can power off normally. If not use the reset pin hole.
Then on reboot you will get the lock screen. You should be able to unlock with your finger as normal. Everything should work from that point.
Now what I do not know is what will happen on next reboot or power off? Your screen maybe hosed up again and you may not get TScalibration to show.
Sorry if that is the case. Again your are testing a fix I "think" will work. Let me know.
If your locked out and cannot calibrate anymore, you will have to reflash the ROM.
