Arnova 10b G2 BETA TESTING THREAD - Finless Bob's "GingerComb" ROM Version 2.1 CWM
You go eat Bob its 11:00 pm here but ill be up at least a couple more hours, if you feel like doin it let me know and ill wait up to flash. I'm willing to wait up I don't go to the tattoo shop till 1:00 pm so if you feel like it just say so.freaktab art developerif you like my work please buy me a pepsi
OK up this AM and ready to work
I have come up with a better way.
I will remap volume up in the built ROM. Then I will provide
nolock.apk
Buttonremap.apk
You will flash the ROM, then reboot. You will come to the lock screen. Use volume up to unlock.
Calibrate. Run nolock to remove the lock screen. Use button remapper to map back the volume button.
Uninstall button mapper.
You will now always have a working system. If the calibration routine ever needs to run again, because lock screen is now off. You will always get to it. However if you want to have the lock screen always, you will need to leave volume up remapped.
Stay tuned.
BETA 2 uploading now.
OK here is beta 2.
Read the README first part for instructions about the button mapping etc.
the rest fo the instructions below that special area is stock instruction. But if you have not read them before please do! There is a lot to this ROM.
ROM -> Arnova 10b G2 Resisitive - "GingerComb" Finless 2.1 CWM BETA2 ROM (215 megs)
ok update upon reboot lock screen comes up even after disable in lock app if you move lock with finger it works but callibrator comes up screen does not respond to touch if you use volume up to unlock screen then callibrator still shows up but screen responds to touch so far everything else is just fine KNOCK ON WOOD have not run into any issuesfreaktab art developerif you like my work please buy me a pepsi
If you reboot using the reset hole, it will cause calibration again.
If you power down using the power button, it should not cause calibration again. Lock screen should be off.
Please test proper power down.
However all this maybe for not.... I think I found an alternative tscalibration.apk that over rides the lock screen.
I am going to have you test it but lets try not to do this with a ROM flash. Get ES file explorer from Google and have it ready on your SDcard. I will send you the new tscalibration and you will simply replace it.
Stay tuned I am testing now.
ok tablet suddenly went all exorsist on me screen started doin what it wanted to touch home browser would open touch settings home screen would come up i let it settle with screen off and now were good installing apps and were fine so farfreaktab art developerif you like my work please buy me a pepsi
If the screen gets wacked out, you lost calibration or it did not calibrate correctly.
Again remember on the Arnova if you do a reset and not a proper power off, it wants to run the calibration again. I wish I could test this stuff but the calibration routine will not pass on my capacitive screen.
There are currently 2021 users online. 3 members and 2018 guests.
