[ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
NYes strange indeed, tried all types of wireless mice. now I'm really thinking there's interference from my TV cable decoder, there's also a dongle in this decoder. Let's try. ....[QUOTE=leolas;185335]that is really strange, we didn't do anything new about mouse. BT mouses? or normal rf mouses?
Re: [ROM] QUICKSHOT V3.1 by The Nitro Team TNT
Originally posted by jacknjill10101 View PostPlease add this keymapping in your next update to fix camera spin for FPS games when using Xbox 360 wireless controller. see details: http://forum.xda-developers.com/show....php?t=1792531
sent by my phone.
enviado desde mi teléfono.
HDMI cable
Originally posted by SUNUN View Postthx bro
This is not a problem with the cable. I bought today a new premium cable and tested with same result as before.
As i remember, i had this isue also with one original minix rom a view month ago. Minix fixed that, the problem was caused by a rockchip update which was used by minix for the new rom at that time.
Originally posted by Hjhoekie View PostHi, Since I installed qs 3 and 3.1 I have a serious problem with my mouse. I almost can't control the minix with the wireless mouse. I came from finless 1.8 and did not experienced these problems . I tried 3 different wireless mouses but none of them seem to work. I'm really disappointed now, because the ROM is excellent. I always used a wireless mouse to control the minix neo x7. Who can help me?
Sent from my HTC One_M8 using Tapatalk
Serious mouse problem remains
Okay, tried out a few experiments, removed wifi dongle from tv decoder, didn't change a bit. Tried to control the minix from very short distance, no effect. The mouse I use now is a 50€ lasermouse from logitech, but the other mice behave the same. And really, there is almost no reaction from the pointer... Any suggestions?
Originally posted by Hjhoekie View PostOkay, tried out a few experiments, removed wifi dongle from tv decoder, didn't change a bit. Tried to control the minix from very short distance, no effect. The mouse I use now is a 50€ lasermouse from logitech, but the other mice behave the same. And really, there is almost no reaction from the pointer... Any suggestions?
You can also do a cross check that it is or isn't a hardware issue with the mice by plugging them into a standard computer... just in case. It's unlikely to have a good brand like Logitech go bad... but it's possible and a quick test on another computer can take that out of the equation as a possible cause.
Oh... while at it... use one of the other USB ports on the Minix also... just in case.
Originally posted by SUNUN View Postyes i find this in amazon.com but shipping to Armenia is missingOriginally posted by rdsok View PostThere have already been a number of people that stated using a good HDMI cable DID fix their trouble. It didn't fix every situation but it is one of the possible causes none the less. So perhaps the issue isn't a cable... but it has been known to cause the trouble so you can't discount it outright just because it didn't help in a few cases.
there is clearly a HDMI setting issue in kitkat kernels that can be workarounded with a good cable (but not too long) or by using 1080p/24 instead of /50 or /60.
1080p/24 is not a perfect solution because video rendering is not smooth with no 24frame compatible video, there is some frame drop to align with sound output.
I prefer 50hz or 60hz for tv shows for example but with a long cable the video flicks in 3.0 and only audio flicks in 3.1.
I think the correct HDMI settings can be tuned in the kernel because wasser succeeded to do it in kernels for k-r42 device.
Franck.for windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Franck.
There are currently 2034 users online. 2 members and 2032 guests.
