[ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Re: [ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Originally posted by kRel View PostThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by leolas View Post
The issue is completely fixed now! It flickered 2-3 times @minute before, used it with this kernel for more than a hour without a single glitch.
The only thing I'm missing now is the overclocked kernel to speed up my DDR for little. Do you plan releasing an updated kernels pack after this fix will go "official"?
Again, thanks!
Again, thanks!
sent by my phone.
enviado desde mi teléfono.
Originally posted by dashdot View PostAnyone got a fix for the lack of writing to external sd on QS3.1?
i have tried to the sd fix apps they say they have worked but it does not fix it
dashdot
Originally posted by rdsok View PostPerhaps you should explain more fully... I've copied data using Root Explorer as well as a XBMC Backup to the external SD card.... I don't think there is an issue unless it is with a particular app or something.
edit... i have tried another sd card and it seems to copy fine ... guess it was an card issue.
Originally posted by dashdot View Posti have tried to copy mp3's from say my usb storage to my external sd and it fails in both es file explorer and root explorer
Oh... one other thing... look at it closely, some cards have a write protect switch on them. They aren't common but do exist.
Cam and static ip bug
Hey guys,
Came to this ROM from the rocksolid QSV2 (skipped QSV3), I'm one of those ppl that upgrades for the sake of upgrading lol... I am wondering if you guys are closer to fixing the webcam bug (where the pictures is way too dark) and the static ip-bootloop bug. I ask as it looks like Wasser's managed to fix both those issues in his ROM (although I have not tried it).
The static IP bug is the one I am particularly interested in as I "need" this to work for my Netflix/UnblockUs setup.
Are these ROMs so similar I can just copy the services.jar file wasser posted here? http://www.freaktab.com/showthread.p...inix-X7/page53 (Post 1057) I don't want to screw anything up now that I have everything else working the way I want....
Can't get the point of having an static IP instead of having IP reserves. I assigned the same IP to my network printer and to my TV. Here there's no Netflix and can't get what is the exact limitation they use... Can you elaborate?
Enviado desde mi SM-N9005 mediante Tapatalk
Originally posted by jcespi2005 View PostDid you try to reserve an IP on your DCHP server (usually your router)?
Originally posted by tltester View PostGuys, is there an option to keep the device awake so it doesn't fall asleep by itself? I've gone through all the dev. options and did't find this one. Am I missing something or it's not relevant to kitkat anymore?
About the static IP, we are trying to solve it too, but look at jcespi2005 answer.
sent by my phone.
Originally posted by jaykl View PostSure, Netflix has different content in all countries they operate in, UnblockUs (a VPN service) allows you to change countries on the fly. This way I get the Netflix worldwide content. The Minix box is set to a static IP, otherwise I cannot change the DNS to reflect UnblockUS' servers. Sure, I could change the DNS in my router, but then all my other devices (phones, tabs and computers) would be going through UnblockUs DNS servers and that would be less than ideal...
Also, you can change permanently by editing the file /system/etc/dhcpcd/20-dns.conf explained here
hello,I am using tigra rom android 4.3...I can't change my dns with the usual method,both apps and manual in advanced setting ,,anyone can help me with this?
Salu2
Originally posted by daemonium View Postsorry i misunderstood, they are different.
I noticed two other things, perhaps the first to know already ...
XBMC Gotham is unstable, often (say always) closes at startup, so you need to restart it.
However I can not run some scripts to see TV channels on-demand. In order to let me know if the failure of the script can depend on the ROM or just from XBMC Gotham ? If it were the latter, can you tell me if i can install 13.0 alongside 13.1, or is it better to uninstall the 13.1?
If I uninstall XBMC 13.1 and wanted reinstall 13.1 personalized Nitro, you have the link?
As you may know, I've solved (!!!) - thanks to leolas - the flickering problem. However, is still present (for what it's worth) in TWRP, of I which appreciate nice graphics and I used to save immediately system state without flickering, because I'm going now to try the kernel that leolas is going to release ...
PS
It would be great if it were possible to use TWRP mouse wireless minixLast edited by kRel; 06-01-2014, 11:02.
Perhaps I didn't explain it properly; the IP address isn't the problem, it's the DNS servers. I can't change them (in Android) without having a static IP in the settings...unless I am hugely mistaken. It's not a dealbreaker; I can use static IP with Wifi for the time being which works, but Ethernet is faster obviously...
There are currently 2585 users online. 3 members and 2582 guests.
