[ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Re: [ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Originally posted by srichar3 View PostThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by gandlaf View PostDear Team
Thank you for your Rom it is great. I have a queston about Quickflasher which does not seem to be working...
I have installed V3.1 directly from PC and Quickfasher was aleady installed. I watched the video and I was not able to find in download sections any quickflasher patch therefore I assume the included in version 3.1 is the latest, which I have upgraded to PRO.
However it does not see t find any packages at all, no matter where I put them, for example the following package:
kernel_leolas_x7_1080p_cpu1704_gpu600_ddr667_quick flasher.zip
Can you possibly assist?
Thanks an regardsThere are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by daemonium View Postcopy the quickshot-update.zip to /sdcard/ and reboot
Wifi issue now sorted not sure if its the new kernel or the upgrading of the rom again but either way its now working.
Originally posted by fabeer View PostHello,i have a problem with my logitech k400 keyboard: the mouse is very laggy and instable...any idea why?
thx
Originally posted by srichar3 View PostI did, and rebooted many times but didnt work, finally I flashed it clean from my pc and then have issues with WIFI not enabling. So I flash a new kernel using the quickflasher. After rebooting following the kernel update it enters the upgrade programme for the v3.1 as the update.zip was still on my external SD card. Must have been something wrong with the update programme in V3.
Weather Widget not updating via LAN
Hello,
I have been testing the Minix launcher and it seems that the weather widget does not seem to understand LAN network, only wifi. While I have a working network connection via UTP it reports no connection.
Is there a way to fix that?
Thanks and regards
Thanks and regards
Originally posted by Productivity View PostI'm still on Quickshot V2 and not sure if I'm ready to move over to KK.
Are there any known bugs other than those listed?
Eg. random reboots, instability, apps not compatible etc?
Thanks!
Originally posted by smokie171 View PostIs xbmc passthrough working on this rom? Sorry if this was asked earlier. I read through briefly and didn't see my answer. Thanks, Kevin
Thanks to wasser for his libmedia patch.
sent by my phone.
enviado desde mi teléfono.
Odp: [ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Thanks!
downgrade
He guys,
New here, and i have to say: great work on qs, its majestic!
I have a small problem with 3.1, as hola and netflix do not work properly (cant find data, and after 5 refresh the wrong region shows up). As this did not happen in qs2, i wpuld like to test it in that rom, to see if it is qs or the hola update. Is there a way i can downgrade from 3.1 to qs2? And if so, how?
There are currently 6554 users online. 1 members and 6553 guests.
