So, I have tested this issue (thanks for the advice on the downgrade!). What happens is the following:
1. Using Hola for US netflix access and the Netflix app in qs3.1; Netflix can't handle the Hola connection. It gives the error 'no data found'. A few refreshes later it loads data, but from my own region while hola is still running. Tried a fresh reinstall of 3.1; same problem.
2. Downgraded to qs2, the problem doesn't exist. I've used the same internet connection, same version of Netflix and Hola app and followed the same procedure on both QS version.
Whether it is really a 3.1 qs problem or not, i can't say. 3.1 was flawless, but i'll stick with 2 for now.
