I know.. but what would be the fix for this?
[ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Originally posted by Van Zeppelin View PostI know.. but what would be the fix for this?
Originally posted by rdsok View PostYou are correct... when you use the power button on the stock remote... it sleeps and the blue led does blink.
Originally posted by chuvk View PostI installed this app from Google store to put QS 3.1 to sleep
Not sure if it works, seems to. Also the power button on A2 puts to sleep.
This will work for now until they officially support kitkat and the standard, stock sleep mode gets implemented (like in QS2) so it actually sleeps after idle time again.
Thanks again for this ROM and for that App recommendation!
~Cheers guys!
uhm... I read that trying to go back to 4.2.2 from 4.4.2 can brick the x7.
But... for example, now I'm on Finless 1.9. I did a nandroid backup using twrp.
if I flash Quickshot 3.1 and then I want to go back to finless, can't I simply restore the nandroid backup as I always do on my mobile?
Does it work in a different way on x7?
thanks.
Originally posted by Soul Reaver View Postuhm... I read that trying to go back to 4.2.2 from 4.4.2 can brick the x7.
thanks.
I don't believe a nandroid backup/restore can address the different partition sizes that JB and KK have.
Originally posted by ngoal View PostLove this rom but I have two problems that should be fixed. One issue is the Google play music does not work correctly it will play one song and then stop. This app works fine on my ouya running CyanogenMod 11 kit kat. It would be nice if this worked because there is no working google music app in xbmc.
Another issue is a major xbmcz problem. I am loving the passthrough for surround sound but xbmcz has a extremely annoying bug that wasn't fixed in your nitroteam edition of xbmc. The included minix remote will not work for the onscreen keyboard when using xbmc. It can not be enabled in input settings. This problem is known to the creator of xbmcz but as far as I know it hasn't been fixed. Does anyone know of a way to fix this.
Im getting exactly the same problem with google play.. Only issue i have
Great rom guys keep up the good work
Originally posted by rdsok View PostOften people that attempted to revert to JB from a KK Rom... THINK they have bricked it but they didn't... there is a procedure outlined in this thread as well as others that tell how to revert and how to correct one that they thought were bricked... It's been a bit since it was posted... but you should find it with a search of this thread and/or forum.
I did not think about different partition size...
Originally posted by Soul Reaver View PostUhm... today I flashed QS3.1.
Still no surround sound and no subwoofer.
That was playing a 5.1 test on youtube.
Tomorrow I will try a dts movie...
Odp: [ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Try download real dts sample from :
Try monster sample with dts using stockplayer or mxplayer first, if there works it will works on xbmc too if you have configured it properly.
Of course go to the options then sound manager and apply spdif if you use optical connection or hdmi passthru if you use hdmi for passthru etc
Higher volume too to hear surround effect. When I was use 1/40 I was no hear rear speakers, on 3 and more it was all good.
There are currently 1608 users online. 3 members and 1605 guests.
