[ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
    Re: [ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
    Originally posted by franckleroy View Post
    Try the special kernel because it fixes an HDMI issue that affect video and audio.
    For me this patch corrected audio glitches.
    Franck.
    I do have flickering so I am using the fixed kernel, the no-sound-after-passthrough is unrelated, unfortunately...
      Originally posted by emtt_medo View Post
      The problem xbmc with the addition of ( xbmctorrent )
      Do not work when you try to run a movie or series
      error
      Script failed: xbmctorrent
      Maybe it is the same problem as solved by
        Originally posted by Productivity View Post
        Great ROM guys! Thanks!
        I just thought I'd share the issues I'm having so far :
        1. The camera is very dark, it seems that the exposure is set way too low by default. And this can't be adjusted in Skype making video calls impossible. I think this should be listed as a known bug in the first post. I may need to flash back to QS2 until this is fixed.
        2. The audio input and output defaults to the Sage Airmouse (Minix A2) after reboot.
        3. There is no option to permanently hide the navbar or disable the touch sounds.
        Other than that it is way faster than QS2!
        The bugs that are listed are those that are ROM related... not bugs/issues that Apps have
        The sound issue with it defaulting to the A2 ( or other ) is how KitKat handles the sound output... the NitroTeam did address it with the remotes that were reported to have the issue but if the remote wasn't reported... obviously they didn't know it did it.... There is an app called SoundAbout in the play store that should help you address the issue for now.
        The navbar behaviour is by design ( for KitKat ) which changed how it works... again some work-arounds have been posted already... I suggest you read the thread ( or use the forum search ) .... I actually mentioned one sound app that may help with the other issue... I won't repeat the suggestion again.
          Thanks for the suggestions. I will give them a try.
          The camera issue is a ROM issue as it was not present in QS2/stock and relates to the general brightness of the output of the camera in any app. Not a specific app problem. I am using a Logitech C525 which I believe to be officially supported by MINIX and one of the more popular devices used with the X7.
          Has anyone had any luck in fixing the camera? Thanks
            http://www.freaktab.com/showthread.p...l=1#post178931
            شكرا جزيلا
            Thank you very much
              How do I give xbmc the powers of your root ( SuperUS )
                XBMC doesn't require root access...
                Programs that do need to read/write to the protected system areas will ask for permission and then you simply allow it....
                  In the original version of the device ( minix rom) sopcast Works smoothly without program works in this version should work program and moves to
                    I think that app you are showing the screenshot of is the one that requires the root access in order to make the change they were talking about.. in otherwords, it was poorly worded
                      What is the way to get to the root
                      I apologize for the language weak
                        The program you are using that needs root access must request root access... SuperSU will then ask if it is ok or not... then you accept it if it is.
                          How's this Rom work in comparison to wassser's kit Kat Rom?
                          Sent from my HTC One using Tapatalk
                            You must test and decide.
                            Please don't start a "what rom is better?"
                            None is better or worse. They are different.
                            sent by my phone.
                            enviado desde mi teléfono.
                            leolas
                            My devices:
                            Gearbest.com)
                              leolas
                              But the kernel is the same for both ROMs. A relative old 3.0.36+. Сorrect?
                                Each one has his own sources, but yes we both use a SDK with 3.0.36+ sources.
                                sent by my phone.
                                leolas
                                My devices:
                                Gearbest.com)
