[ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Re: [ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Originally posted by ilikenwf View PostMaybe I should just install finless and wait until minix comes out with a 4.4.x build, and he releases a new version of the finless rom?
There are people with problems with some roms, but if we can't reproduce the problems is hard to try to solve them, I tested the rom with all the hdmi cables I have in home and in all the I had before published the rom, and none of them give me problems.
sent by my phone.
enviado desde mi teléfono.
Really weird Wi-Fi issue
Yesterday I decided to try another rom out of curiosity, so I temporarily left QS3.1 and installed the other rom (Finless). Well, I wasn't happy with the performance and decided to go back to QS3.1. However, when I reflashed and then rebooted it, I could not turn on wi-fi. It would just sit at the setting up wifi screen saying "turning on wifi" and just never would turn on. I reflashed the rom again, thinking maybe a bad flash or something. Same deal. I flashed Finless again just to make sure wi-fi actually works, and it picks up and works fine here. Reflashed QS3.1 *again* and still not turning on. I bypassed the initial wi-fi setup and went into the settings to turn on the wifi. The switch will not move!
I have never encountered anything like this before. QS3.1 initially (before I did any other flashing) was working fine with wi-fi. Now I simply cannot get this rom to activate/turn on the wifi. What gives?
Originally posted by zektor View PostYesterday I decided to try another rom out of curiosity, so I temporarily left QS3.1 and installed the other rom (Finless). Well, I wasn't happy with the performance and decided to go back to QS3.1. However, when I reflashed and then rebooted it, I could not turn on wi-fi. It would just sit at the setting up wifi screen saying "turning on wifi" and just never would turn on. I reflashed the rom again, thinking maybe a bad flash or something. Same deal. I flashed Finless again just to make sure wi-fi actually works, and it picks up and works fine here. Reflashed QS3.1 *again* and still not turning on. I bypassed the initial wi-fi setup and went into the settings to turn on the wifi. The switch will not move!
If you use the right version, try this:don't change language in the setup wizard, and pass the initial wifi setup and when wizard ends, wait 5 minutes without try anything. then power off the device and power on again (not reboot) then activate wifi and see if it works and configure the rest of the settings.
sent by my phone.
Originally posted by leolas View PostSorry but I must ask it, have you installed the neo x7 ROM? some people download the mini version.
sent by my phone.
leolas
In any case, I will just be flashing QS3.1 and thats it from here on (and any updates from you as well of course). This is bar none the best rom available. I also have a RKM MK902 coming and was really happy to see QS3.1 available there as well
Originally posted by tltester View PostHi. I wanted to report another small glitch on my QS3.1 on X7 - after playing 5.1 with pass-through on XBMC I have no sound on my Pioneer receiver (connected with HDMI) until I turn it off and on. This is quite consistent and happens only with KitKat (was fine with 006c)...
tode
Originally posted by tode View PostThe default one.
I never got flickering problems,
tode
For me this patch corrected audio glitches.
Franck.for windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Problems encountered so far
Great ROM guys! Thanks!
I just thought I'd share the issues I'm having so far :
- The camera is very dark, it seems that the exposure is set way too low by default. And this can't be adjusted in Skype making video calls impossible. I think this should be listed as a known bug in the first post. I may need to flash back to QS2 until this is fixed.
- The audio input and output defaults to the Sage Airmouse (Minix A2) after reboot.
- There is no option to permanently hide the navbar or disable the touch sounds.
There are currently 2005 users online. 0 members and 2005 guests.
