[ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
    Hello! I've been using Quickshot v2 for a while now. I tried updating to v3 BUT I cannot seem to install the driver properly on Win7. I have spent hours reading and following different forums for a solution and I stil can't get it to work!
    My computer doesn't really recognize the Minix X7 properly. Rkdevicemanager and all the other devicemanagers can't detect the x7. Windows can... but the drivers are not properly installed. I tried uninstalling the drivers to install the proper drivers but it doesn't work... it just either says I have the latest drivers or they can't find the drivers when I direct them to the driver folders.
    Pleeeeze help me.
      question about firmware 011
      Hi to all. I am using x7 neo minix, which i bought with firmware 008 and i "installed" quickshot 3.1 custom rom..
      I am fairly new to andorid devices, xbmc, Minix neo x7 and using custom roms.
      I was wondering, can i upgrade to 011 version of firmware for x7 minix neox7, and do i lose all my settings, setups and installed apps by doing that?
      Or does this quickstot v3.1 custom rom has upgrade to 011 firmware embedded inside?
        Hi I have installed QS3.1 on a few minix x7´s
        but i have tried to install it on another x7 and i can get wifi to turn on
        any advice?
          Re: [ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
          Sorry for the late answer.
          Originally posted by willynanita View Post
          I am trying to mount a shared folder using cifsmanager but I keep getting "invalid argument" error. My setup is as follows:
          share path: smb://10.0.0.9/sharename/
          mount point: /mnt/cifs/
          username: guest
          password:
          options: none
          I can see the cifs folder where it should be, but I doesn't work, I keep getting the error.
          Any help will be appreciated.
          Have you tried the init.d script that comes with ROM to mount cifs points?
          Pleeeeze help me.
          Please, try the steps in the video from the first post carefully, it works always for me, if the x7 is not recognized, change the USB cable, change the USB port, or try in other PC.
          When you flash an official firmware, you always loose your settings.
          any advice?
          Reflash, maybe a bad flash.
          My devices:
          Gearbest.com)
            Reflash, maybe a bad flash.[/QUOTE]
            i have downloaded the firmware a few times no change
            the wifi is stuck on turning on
            my wifi works on other roms but i prefer qs3.1
              Make certain you are getting the proper ROM for your device... the X7 and the X7 mini use different wifi/bluetooth chips which is why there is a QS3.1 for each one.
                Make certain you are getting the proper ROM for your device... the X7 and the X7 mini use different wifi/bluetooth chips which is why there is a QS3.1 for each one.[/QUOTE]
                Right. Xu and x7 mini has his own ROM and kernels packs.
                my wifi works on other roms but i prefer qs3.1[/QUOTE]
                Are you sure that it is a real x7?
                My devices:
                Gearbest.com)
                  Just to be clear... the quotes were messed up starting with dashdot's post ( they had edited them incorrectly, messing up the quote tags )...
                  I didn't ask for the info... dashdot had. So both my own reply ( which I've now fixed the quote on ) and leolas's are directed at dashdot and say the same thing.
                    I haven't, I don't know where to find it or use it.
                    EDIT: I just read this on the first post: "NFS example script included under /system/etc/init.d , just edit to suit your needs and you will have your nfs shares mounted every boot."
                    I will try that.
                      Hi Leolas, Nitro team,
                      i've been trying for a while to recompile a kernel of my own without much luck. I'm only interested in getting a driver for my touchscreen in.
                      May I ask that one of you guys take those 2 files, and compile your kernel with them by any chance?
                      I would really, really, really appreciate!!! Beer would be on me next time for sure...
                      thanks
                      HID_source.zip
                        thanks
                        [ATTACH]7617[/ATTACH]
                        We will try to include them.
                        My devices:
                        Gearbest.com)
                          Rom Installs
                          One frustrating thing i find with installing some Roms is the Setting are set to a 1080 tv. If you have a 720 tv trying to find your way through a mismatched resolution to video settings is brutal at best. The intial setup stage is terrible as you only get a flash of the screen.. Sometimes it can take over an hour to set video to 720
                            With most ROM's (as with this one) this can be overcome by flashing a 720p Kernel after flashing the ROM itself.
                              I really need help with Archos Media Player and QS 3.1
                              Archos worked "fine" when I was using the Xtreamer MC Rom. I say fine, because the video played great on that rom, but the app crashed a lot and it was almost unusable.
                              Using QS 3.1 Rom (and I do want to keep using this rom) the video is not played smoothly using Archos, but using MX Player the video plays great.
                              I really want to use Archos as my media player but I can't watch a movie because video motion is like frame by frame.
                              Using Archos to launch MX Player is not an option because Subtitles are not loaded in MX when I launch the videos from Archos (it must be because the smb folder is not mounted, I don't really know). I tried to edit the file located in system/etc/ to auto mount smb shares, but I can't save the file after edited.
                              My workaround, so far, is to use the ES file browser to launch the movies, that way MX loads the subtitle (I don't like that option and I've had to go back to using the Apple TV 2/Infusion option )
                              How can I fix Archos media player with this rom, I really don't want to install the Xtreamer MC rom.
                              Thanks in advance!
                              Willy.
                                Thanks in advance!
                                Willy.
                                Was xtreamer mc a 4.2 ROM?
                                My devices:
                                Gearbest.com)
