Is there a way to save that option or change the defaul selection ? Thanks !
[ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
Originally posted by iegolas View PostI installed this rom some days ago. I have a sound problem because everytime that I reset the Minix Neo X7 the option that I selected in Audio Devices Manager to select the audio ouput is reseted to the default value.
Is there a way to save that option or change the defaul selection ? Thanks !There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by Limitless83 View PostHi
Stupid question, and might've been asked before...
But I accendentaly hid the notification bar and now i can't seem to get it back... where's the setting or the keyboard shortcut?
L.
If you meant taskbar... I believe you use your pointer and click and drag it up from the bottom.
A2 sounds
Hello,
To the developers of this amazing firmware goes a huge thanks.
I have two things I'd like to solve though. The first. It says in the description of this release that the A2 air mouse sound will not be used by default. But after a reset it is still set to that. The soundabout app sucks because I can't set it to SPDIF pass through. I'm using the optical output ie. toslink. Anyone fighting the same issue?
The second. I Also noticed that there is an annoying sound when I move in the menus using the arrows on the mouse. How can I turn this off? I'm using the NULL key mapper. Haven't seen the settings in the menu.
Thanks so much. Keep up the good work.
Hey, I'm a loyal quickshot user but have an issue every since kodi came out (and spmc updated to kodi) .
With hardware acceleration on, I get random horizontal artifacts for a split second on the bottom of the screen. It happens every so often through a show. If I turnoff hardware accell, both or only one of the codecs it is fine. But I would prefer to have hw accell.
Any ideas?
Originally posted by Fedur View PostYou can use youtube plug-in in xbmc to watch full hd video. On normal apk youtube on android 720p is max. Maybe non standard - custom youtube apk will help you.
There are currently 2845 users online. 2 members and 2843 guests.
