[ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
    Version 3.2 is around the corner
    We got a little diverted because we are trying to bring you guy's something different.
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
      Sweet! Triple 4
        CyanogenMod!
        Very very good
        tode
          Sweet!
            Android 4.4.4. AWESOME!!!!!!!
              Android 4.4.4 sweet!!!
              hope it works as well as existing rom!
              Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
              HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
              ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
                i didnt even notice it is a cyanogen mod rom! cool!!!
                  awesome dev guys ...longtime not used X7...I am eager to flash n playing it with your new version...3.2 ...let see how...tks dev team ...God bless!
                    Flickering problem
                    Hello,
                    I have the flickering problem ( I had the same issue with a PIPO tablet only in the TV I have now the minix).
                    I have downloaded the kernels. I am trying to use the 1080p. Is there a "wise" way to test them or just randomly and probably one wont flicker?
                    Also in case this issue still happening is there a guide how to return to official NEO_X7_20140101 ?
                    Thanks a lot.
                    EDIT:
                    So i get 1s blackout every sometime (1 every 2-3 minutes maybe, sometime less sometime more, not so predictable).
                    I feel that before trying the kernels pack I was getting less blackouts, not sure though. Also after starting trying kernels pack I see some random white lines in the screen (especially when QS3 logo loading and white lines are easy to spot).
                    Also sometimes do 2 blackouts in the row (having 1-2 seconds difference one with the other.)
                      Odp: [ROM] QUICKSHOT V3.1 by The Nitro Team for Minix Neo X7
                      Dear Nitro Team can you add proper key layout keyboard rii i8 from other topic: http://www.freaktab.com/showthread.p...ll-mini-H7-etc I just buy rii i8+ and need fixed key layout plz
                        Originally posted by creyentes View Post
                        Hello,
                        Thanks a lot.
                        EDIT:
                        Use a good quality HDMI cable... between the blackouts and the white lines, it's more likely the cable causing them ( if you've made sure they were plugged in good already on both sides )
                          Hello,
                          How you mean good quality hdmi cable? what features should have? Can you please link me one that is good quality?
                          Thanks a lot.
                          EDIT: The white lines are not full lines, are small flashes random in screen rarely and visible only when background is dark.
                            Hello,
                            Thanks a lot.
                            A good quality cable means just what it says... not a cheap cable... purchase them from a known good vendor and don't buy the cheapest thing you can find. The one that comes with a Minix device is a good known quality as one example.
                              It's not the cable then as I use the one from minix box.
                                I would agree it is less likely... but your logic is not taking into account that cables can and do go bad sometimes. It's also possible that just the HDMI port you are plugging into on your TV has an issue and using different one ( if available ) may help.
