____________________________________
OK folks so the 104K4 came out yesterday!
Not to waste any time I went ahead and made my 1.6 ROM
This is based on the S82/S89 104K4 ROM.
I have not really done anything to it different than I did in 1.5 ROM. Same tweaks and such but to the new 104K4 release since it fixes some bugs people are having. Well I did change a few little things
I also know 105K4 will be coming next (please don't ask me when or how long!). So rather than wait for it, I figured just do a quick 1.6 ROM using all the scripts I used to make 1.5. Worked perfect
By the way, I noticed something major in 104k4. New mali and other kernel modules (.ko modules).
So for sure there is some changes in here!
Features and release notes for my 1.6 ROM:
1) Properly rooted using SuperSU. What does properly mean?
Android 4.4.2 requires SU to be running as a daemon now. There are many ways to run this as a daemon.
Most roots so far are using a install-recovery.sh script or if init.d is enabled, a init.d script.
This means you could lose root if messing with these scripts which some rooted apps do!
What I have done is started the daemon in init.rc thus eliminating the need for boot scripts!
This took me a while to learn to do! Enjoy a BETTER ROOT!
2) Updated Google framework and Play Store core files. The ones in the stock ROM were out of date.
On first boot NOTHING will need to be updated once you logon to Google Play.
3) Debloated of junk APPs and Google Apps you can get from Google Play.
There was quite a few useless hidden apps in this KitKat release! Some of them did not even work.
I did remove XBMC and other pre-install APPs as well. I like a CLEAN ROM that you the user can setup the way you want. Having APPs in /system leaves that junk in there forever (unless you delete them by hand with a root explorer). If you want the original XBMC APP then download it from Geekbuying.com
4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
5) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device (Nexus 10) that will show almost any APP as compatible.
This should also allow Netflix HD but I have not tested it.
Your device will show up in google play as Nexus 10 device not a Vega S89! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a Vega.
7) I added a reboot APP that will allow optional reboot options like reboot to recovery for easier updates.
8) Carrier spoof (T-Mobile) for better APP compatibility.
9) The usual tweaks I do for better performance e.g. TCP buffers sizes, etc etc.
10) Added bonus! CPU fixer patches!
In this ZIP is a CPU_fixer folder. These zips can be used to adjust your minimum CPU frequency and Governor.
See the README.txt in that folder for an explanation and how to install them.
________________________________________________
OK so here is the download!
READ the README.TXT in the zip for instructions!
ROM -> Tronsmart S89 / Beelink S82 - Finless ROM 1.6 (304 megs)
