Tronsmart S89 / Beelink S82 - Finless 1.6 ROM
Originally posted by Finless View PostRK3288 Devices
- Overview BOX (LINK !)
PS:
they handle it via busybox softlink...
BUT I know, that the problem is, that many (most) HDD need hdparm but some (less) need sdparm, so you can also choose which one you want to use (in addition to e.g. the time value)...RK3288 Devices
Originally posted by mykei View PostNo idea why, but it won't mount the SDCard in recovery for me.
I did manage to get it working via installing from an USB Stick.
Awesome work Finless, thanks again.I hope you have fun with my english writing!
Now Draco Meta...coming from Vega S89-H, wdtvhd 1, xtreamer 1, zotac ion, raspi and some android smartphone skills
Originally posted by techsupp006 View PostWhich backup method did you use? I also don't want to get off the couch
What wasn't back the way it was?
Download the rom that you wish to use, it must be in a zip format, right from your android box. Bob was the first one to convert the rom into a zip format, but now the factory gives a zipped rom also. After the rom has downloaded, use your file manager to unzip the file. When it is unzipped, in Bob's rom, you will find 3 files, 2 zipped and one readme file (also his rom has cpu fixer zip files.). Your file manager will have an option to extract the files from the rom that you downloaded, just extract the files to the root of your micro sd card. After the zipped files have been extracted to the micro sd card, just open the "udate&backup" app. select the file that you want to "update", (the files that you extracted to the micro sd card) will show up for you to select. Select the rom you want to update, then click the update button. You may want to check the "wipe data" and "wipe media" so you have a clean install.
After your box reboots and installs the new rom, it will find the file that had your backed up data and will ask you if you want to restore your data.
As I recall, all my apps and settings and logins were restored, but I did have to tweak the home screen settings.
One thing to make sure of, is that your micro SD card is formatted in fat32.
Hope this helped.Last edited by clarkss12; 31 May 2014, 16:19.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
game controller
best game controller for this box?Last edited by william265; 30 May 2014, 17:38.
Originally posted by william265 View Posthey there I got this box s89-h on its way and plan on doing a in depth video review of this box on my youtube channel and have a hd audio avr full hd tv and a nighthawk ac1900 gigabit router and huge 14 tb of Blu-ray iso storage. Is this the proper rom for the s89-h? I want the latest fixes and custom rom for testing and im very interested in the cpu fix in rom but im a little confused on what it actually does. I mean I understand it lowers or raises min cpu and max cpu but what is the best performance / stability setting to use on cpu fix? also how do I test dts/dd hw decoding? ty for your time and please if u can answer my 3 questions tylink to youtube channel Link removed as spam
Lot's to learn and only study and reading here will give you the expertise to know and do a review properly. All that you are asking and require is posted here! Spend some time doing your research rather than asking for an instant answer so you can do a youtube review.
Anything else is just another youtube bunch of garbage. Sorry to be harsh but reality my friend.
There are already a ton of youtube reviews that add NO VALUE to anyone other than "hits" so someone can get youtube points. Honestly, anyone that knows anything about these boxes don't care about another n00b youtube review.
Hi all !! I'd like to say thanks you bob for the great job !!
But i've a little prob, notre with the ROM but with xbmc, i can't configure my xbmc with my nas because my tronsmart can't access to my nas with xbmc.
Can you advice me ? I've the latest xbmc modified and i've tried with the latest official
Envoyé de mon GT-N7100 en utilisant Tapatalk
finles ouch im hurt lol j/k
hey im not just a noob that don't know s*** but at same time im not a programmer in anyway or a android rom pro lol, I have done all kinds of things with tech and have read a lot on this forum about this unit but I wanted to know for sure this rom was for the -h ver as in post listing it says s89 now about ur cpu fix do you have a recommended setting,or trial n error? also all I know from reading about hw dts/dd decoding is if u don't have it software players like mx will produce no sound from those dd/dts sources so I wanted to know how to test that specificly besides trying the playes. Am I way off?? also im doing a review because I have found no videos that show off the things that interest me like full blu ray iso playback with menu,testing 5ghz wifi high bitrate mkvs with hd audio a lot is not touched on in most reviews and im not proclaiming to be a master just think some people may want to see some of the things working on video ty for your response and your hard work on your roms and dev I will deff be donating to the couse
netflix probs
Is anyone still getting the blurry/stuttering/distorted image in netflix with this rom? I'm using 1.5 right now and everything is great except the netflix problems.Tronsmart Vega S89 Elite Amlogic S802 with finless2.0
Tronsmart Draco AW80 Meta Allwinner A80 Octa Core finless1.0
I have Netflix playing RIGHT NOW. I watched "The Host" and am now watching "Aeon Flux".
It is perfect and way better than any RK device I have.
I do not understand why others are having issues to be honest.
There are currently 3594 users online. 1 members and 3593 guests.
