Tronsmart S89 / Beelink S82 - Finless 1.6 ROM
    Re: New - Tronsmart S89 / Beelink S82 - Finless 1.6 ROM
    Originally posted by madweegie View Post
    Yeah I use Iplayer via XBMC plug in , the only way it works
    Sent from Note 3
    I wrote about this on another thread. Can't understand why IPlayer won't play videos, its maybe a codec thing, i don't know. 4od will play videos if you use the 4od Xposed module to enable HDMI playback with it. Channel 5 needs the Xposed root cloak module and Sky Now TV/Sky Go just does not work at all its checks are too strict. I also tried the TV Catchup app and it gives strange slowed down playback. Most of the apps can be played through XBMC plugins so its not that big a deal.
    Sent from my Nexus 5 using Tapatalk
      @Finless
      Hi Bob,
      I have test your cpu_fix_816 (104k4) at stock rom 104k4 for -H and find out, that there is a problem with the heat, maybe have a look at http://www.freaktab.com/showthread.p...l=1#post190080
      Because of this, I ask you, please can you also build for testing
      - one with 0.0096GHz @ 4 core / interactive
      - and please also with 0.0096GHz @ 4 core / interactiv BUT from -H rom (maybe also 0.816)?
      (http://blog.geekbuying.com/index.php.../#.U4PoIyg5WCA)
      This will be really nice!
      THX
      RK3288 Devices
      - Overview BOX (LINK !)
        Originally posted by wolfe View Post
        Thanks, I assume you are running Finnless 1.6?
        Can you be more specific about what data needs to be cleared in the apps list?
        So would you say that if I cleared that data and updated to Finnless 1.6 it should work, or is it that this data clearing is a constantly repeating maintenance?
        I go into settings App manager, and clear data for google search. I am currently on the test rom but was on 1.6 and had it working there also.
        TV catchup also works fine for me apart from when I try to change channel
          TV Catchup the app? I'm running 104k4 and for me it runs like its playing in slow motion.
            Same, just trying to watch french open...
              Canal + app don't work well on my box. Vidéo freeze, i've tried with wifi and ethernet and i've the same prob althought my 30mb internet
              Envoyé de mon GT-N7100 en utilisant Tapatalk
                There's an XBMC add on for it and it works fine in that.
                    Hi Finless
                    I want to try your firmware
                    Plz can you tell me if i can install it on a S82B version ...
                    I think I can but I prefer to ask before...
                    thx a lot for your job
                      The B means that my version have the AMLogic S802B chipset support hardware decoding Dolby and DTS...
                        Yes TV catchup the app! You have me second guessing myself now so I shall pop out to my car (where my tronsmart is installed) and double check.
                        Ok, you guys obviously cursed me because now mine is running slow seriously though this must have been a fairly recent update as now I can change channels properly but when I do it runs slow
                          When I play my 1080p mkv films from my hdd I get a small stutter about every 10-15 secs. Im on 1.6 finless rom s89-h. Was also the same in my s89 standard with 1.4 rom. Anyone ideas how to stop it?
                          Sent from my SM-G900F using Tapatalk
                            Hardware acceleration. Only have Libra ticked for mkv 1080
                            Stick on debug setting on xbmc and you will see fps steady at 24fps. Other hardware settings aml and media fps all over place never steady at 24fps causing them glitches you see
                            Sent from Note 3
                              Where is the options for that then?
                                Xbmc then settings then video then acceleration
                                Sent from Note 3
