Tronsmart S89 / Beelink S82 - Finless 1.6 ROM
I haven't got xbmc installed. I've just been using mx player. It does it on 4k player, mx player and the stock media player. Is xbmc the only way of playing full hd vid without any stutter then? My cs918s plays then fine, thought this box would be the same.
Sent from my SM-G900F using Tapatalk
Originally posted by Nowandlayda View Post... make sure in developer options under your android settings you have enabled hardware acceleration.RK3288 Devices
- Overview BOX (LINK !)
Originally posted by stookas View PostI haven't got xbmc installed. I've just been using mx player. It does it on 4k player, mx player and the stock media player. Is xbmc the only way of playing full hd vid without any stutter then? My cs918s plays then fine, thought this box would be the same.
XBMC is really the best method for playing all media really, its this one you should use if you do want to go down that route. http://blog.geekbuying.com/index.php...-rmvb-support/
i never had to enable any settings in developer mode , it should all be done for you.
PS3 dualshock with Sixaxis
Does anyone have success to connect PS3 Dualshock (or other) with SixAxis app on this box? Its working via cable but not via bluetooth :/
It just not pickup my ps3, blutooth address is set fine with pair.
Its working on my nexus5, so controller is fine. I noticed sometimes it shows segmentation fault when listening for controllers.
Originally posted by JIV View PostIt just not pickup my ps3, blutooth address is set fine with pair.RK3288 Devices
Originally posted by no_spam_for_me View Post@Finless
Hi Bob,
I have test your cpu_fix_816 (104k4) at stock rom 104k4 for -H and find out, that there is a problem with the heat, maybe have a look at http://www.freaktab.com/showthread.p...l=1#post190080
Because of this, I ask you, please can you also build for testing
- one with 0.0096GHz @ 4 core / interactive
- and please also with 0.0096GHz @ 4 core / interactiv BUT from -H rom (maybe also 0.816)?
(http://blog.geekbuying.com/index.php.../#.U4PoIyg5WCA)
This will be really nice!
THX
Originally posted by no_spam_for_me View PostPPS:
It seams so that they fake something to handle the CPU management at 104k4
If I stop the stress test after long time (more than 2 hours) running (@3cores @1.2GHz @70/75°C), the temperature jumps from 75°C back to 55°C in one step after maybe max 1 minute and some seconds later it jumps back to 40°C...
If I restart the stress test it runs first short time @4cores @1.6GHz and temperature jumps up and active cores and frequencies will be less ...
I my eyes it seams so, that they fake the temperature in conjunction with frequencies (and maybe also cpu usage) and manage the cpu with this fake temperature-value...
=> that's why the cpu fixes > 0.8GHz useless (definitely at -H) because you get a higher start temperature and never reaches the 1.9GHz and only short time the 1.6GHz before the frequencies get lower and lower and ...RK3288 Devices
When I get the time I will make it.
Originally posted by Finless View PostWhen I get the time I will make it.
It looks a little bit better, but maybe 96 is to less, because the cores often jump to 1.992 so because of that the temperature also rises to high (not the real temperature) and the max feq jump between 1.6/1.9 at idle...
Maybe, because of CPU usage at ~5% at idle i will also try the next possible steps and maybe find an ideal min freq...RK3288 Devices
If 1.6 Rom is based on 104K4 ROM, is it possible to apply CPU
fixer patches to official and unmodified 104K4 ROM?
Originally posted by Finless View PostOK folks so the 104K4 came out yesterday!
Not to waste any time I went ahead and made my 1.6 ROM
This is based on the S82/S89 104K4 ROM.
10) Added bonus! CPU fixer patches!
In this ZIP is a CPU_fixer folder. These zips can be used to adjust your minimum CPU frequency and Governor.
See the README.txt in that folder for an explanation and how to install them.
Originally posted by steliosg13 View Postguys I have the -h and connected to my sony dts-hd capable receiver. I can confirm that with the stock 4k video player and android video player dts is not hardware decoded. I have yet to try MX player. Also, DTS-HD passthrough through xbmc is not working as per geekbuying. I have enabled the options and I can only see the AC3 capable receiver and DTS capable receiver option. It does play the DTS audio though. I am using the latest gotham 13.1 release candidate. On previous xbmc versions i remember seeing DTS-HD capable receiver option. Have they removed the DTS-HD passthrough capability on the latest Gotham version? I very much doubt it! Can someone shed some light into this please? While playing the video in XBMC and go to audio options it does recognise the DTS-HD as audio upstream but it only passes through DTS to my receiver.
edit: MAYBE THE FIRMWARE IS TO BLAME BECAUSE THIS IS THE -H VERSION?I haven't tried with the stock firmware that came with the box as I have flashed Bob's firmware immediately
Originally posted by lawin1 View PostIf 1.6 Rom is based on 104K4 ROM, is it possible to apply CPU
RK3288 Devices
OK, can you clarify one more thing:
Originally posted by Finless View Post<...>
9) The usual tweaks I do for better performance e.g. TCP buffers sizes, etc etc.
Originally posted by Finless View PostIn boot.img I have also made changes to support root, init.d, etc. So it may work on stock but I have not tested it. You can try it as it wont hard brick you but I don't know what errors you might get because files that support root and init.d wont be there in /system.
There are currently 3195 users online. 1 members and 3194 guests.
