It works fine in xbmc though, u can select the keys once you enable remote key presses in settings.
Tronsmart S89 / Beelink S82 - Finless 1.6 ROM
Originally posted by tiguy82 View PostI have a S89-H and I installed the 1.6 version with no issues, the only problem I have right now is regarding the Shutdown, if I select "Turn Off" option on the reboot menu the box restarts instead of shutdown And the power button doesn't seems to work.
Originally posted by warlock09 View PostJust a question will this device be compatible with this rom..thanks...??
Sent from my GT-I9505 using TapatalkRK3288 Devices
- Overview BOX (LINK !)
Re: New - Tronsmart S89 / Beelink S82 - Finless 1.6 ROM
Sent from my SGH-I747M using Tapatalk
The S89 still freeze after few minutes
Originally posted by stb2xxx View Posthi format usb flash to fat32 copy 1.6 rom and get update app if have com.android.system problem Chang system language to english enjoyHi,
you helped me with both cases: 1.6 ROM installed with the com.android.system problem.
Thank very much.I still have a very High problem that I hoped the new ROM will fix it: The S89 Freeze after few minutes of working.I am much desponded. All what I tried are not succeeded.I have the devise more than a week and I didn't see one Movie or TV series.I am still hoping someone can help or I have a HW problem??
Can anyone recommend a app for the following...
I have 4TB HDD connected in 1 usb port , i connect 2nd USB in port 2,
But ive tried using EfS/HD File/ Root Explorer , all failed in trying to move files from USB 2 to USB1 , as i dont want to disconnect the big USB just to transfer movie files from PC to that USB , surely easier way.
If the destination use NTFS you have to use Paragon
(no kernel support at the moment)RK3288 Devices
There are currently 1610 users online. 0 members and 1610 guests.
