Tronsmart S89 / Beelink S82 - Finless 1.6 ROM
    ah yes it is ntfs
    Sent from my Kindle Fire HD CyanogenMod 11
      Originally posted by no_spam_for_me View Post
      If the destination use NTFS you have to use Paragon
      (no kernel support at the moment)
      Yes I researched this a bit. Wanted to enable NTFS in kernel, but this is still in development (like in the past 10 years!) & slow (experimental write support). Paragon, using FUSE, is the fastest and works very well aparently (close to native speeds).
        So far, so good...I only want to mention that paragon needs root, doesn't it?!
        Even though I think everybody here has rooted his device...
        I hope you have fun with my english writing!
        Now Draco Meta...coming from Vega S89-H, wdtvhd 1, xtreamer 1, zotac ion, raspi and some android smartphone skills
          Yes Paragon needs root and it works perfect
          Sent from my GT-I9300 using Tapatalk
            Originally posted by korenspeed View Post
            you helped me with both cases: 1.6 ROM installed with the com.android.system problem.
            Thank very much.
            I still have a very High problem that I hoped the new ROM will fix it: The S89 Freeze after few minutes of working.
            I am much desponded. All what I tried are not succeeded.
            I have the devise more than a week and I didn't see one Movie or TV series.
            I am still hoping someone can help or I have a HW problem??
            hi
            i think you have hardware problem may return the device to the seller I think it's a bad solder cpu or ram
            any way can replace 5 volt ac adapter with anther ?
              Finless Rom with Tronsmart s89-H
              Tronsmart S89-H Dolby - DTS unit $ 130.00
              Finless rom 1.6 reasonable donation $ 25
              XBMC version 14.1 with a reasonable donation $25
              Being able to watch a movie with liquid smooth video and have the audio in sync to people talking..
              PRICELESS
              Thank You for such a great job on this ROM Bob.
              Android is now becoming real for other TV box replacements.
              NO seriously, this box with this rom will replace anything out there. I currently has a cs968. That unit is
              going to the daughters bedroom.
                Just need improved netflix or even better a Android version of xbmcflix lol
                Sent from Note 3
                  What's peoples general setup when comes to media curiously :-) usb / nas / pc network / as I've had no issues via usb and pc network via power plugs. I dont use wifi
                  Sent from Note 3
                    Flash it on my measy b4a and works great only one think if any one can help in mx player eventhough i installed the custom codec for dts i get no sound if i dont enable s/w decoding sound
                      Seems that your device has no hardware support for dts
                        No i believe its something else cause bsplayer has sound but mx player dont the same movie
                          But custom codec from XDA ARE for SW decoding... So if you want to use them of cause you have to enable SW decoding at MX...
                          If you have a -H and MX with HW decoding did not decode the audio at that video, maybe somethings wrong with your MX and/or the video...
                          RK3288 Devices
                          - Overview BOX (LINK !)
                            Confused
                            I was able to read and write to an external attached hard drive with my neo minix neo x7 with the same hard drive so why can't this work with the vega s89. Just wondering.
                              Would rooting allow me to change the aspect ratio and overscan / underscan within the Android interface? It doesn't help me if its only XBMC.
                                kitkat happened the x7 ran on 4.2.2
