HPH Android TV BOX RK3288
Originally posted by jokickass View PostIsn't the max 3GB on a 32bit arm cpu?
There are a lot of 32 bit SoC able to be assembled with 4 Gb of RAM, but the 32 bit OS frame or architecture is not able to use effectively more than 3 Gb, I Guess the exact max amount is 3.2 Gb; It´s the same for a 32 bit PC OS. To can take advantage of the 4 Gb of RAM or more a 64 bit system is required, if not there is not a real reason to have the 4 GB of RAM.
update
Email from Tina today, price for 2g/8g is $128 shipped to be ready in 10 days. No update on 4g model availability yet.
*CPU: RK3288 28nm Cortex-A17 Quad core *GUP: Quad-Core Mali-T764 3D GPU Support OpenGL ES1.1/2.0/3.0, OpenVG1.1, OpenCL1.1 and Renderscript , Directx11, 2D GPU support 8Kx8K input,4Kx4Koutput
*RAM: PDDRIII 2G/4G optional
*Nand flash: 8G/16G/32G max up to 64GB optional
*HDMI2.0,Support 4K x 2K decode output
*HDMI Input: Support max up to 1080P(60Hz) input
*Support H.265 Hardware decoding
*Support 1000MB Network
*3 x USB Host,
* 5M Cam(Optional)
*OS: Android 4.4
Thanks for the info.
Same price and specs as the Ugoos UT3, although the HPH looks better imo. Will keep an eye out for this one.
Here is a more complete list of features:
(Translated from http://item.taobao.com/item.htm?spm=...id=38940292603)
Hardware Specifications:
CPU Processor: RK3288 28nm Cortex-A17 Quad-Core Processor
Graphics Processor: Embedded Quad-Core Mali-T764 3D GPU, support OpenGL ES1.1/2.0/3.0, OpenVG1.1, OpenCL1.1 and Renderscript, Directx11, 2D GPU support 8Kx8K input, 4Kx4K output
System Memory: LPDDR2 2GB (4G optional)
Storage capacity: 8GB Flash (16B/32GB/64GB optional)
Network: Wireless: Support Wi-Fi 2.4GHz/5GHz 802.11 b / g / n & 802.11 a / c, cable: Support 100M/1000Mbps Gigabit Ethernet Base-T standard.
Bluetooth: Bluetooth 4.0
Storage Expansion: Support MicroSD (TF) card, up to 32GB
Power supply: DC 5V/2A
Operating System: Android 4.4
External Interface
HDMI output: 1xHDMI A-type female, HDMI2.0, support 4K × 2K decoder outputs
HDMI input: 1xHDMI A-type female, maximum support 1080P (60HZ) Input
USB Interface: 3XUSB Host, 1XOTG (Micro USB)
Fiber Interface: 1xSPDIF digital audio output
Reader: 1xTF deck
AV and analog audio output interface: 1x3.5mm headset seat
Network Interface: 1xRJ45
Power Interface: 1xDC socket
Antenna: External antenna Wi-Fi
Camera: 5,000,000 AF (optional)
MIC: no noise no echo silicon microphones
Audio Video
Audio formats: support for MP1, MP2, MP3, WMA, WAV, OGG, OGA, APE, FLAC, AAC, M4A, 3GPP and other audio formats, a variety of EQ mode, support synchronous lyrics display lyrics and the whole page
Audio Output: HDMI audio output, left and right channel analog audio output
Video decoding formats: Full video format decoding, support for H.265 hardware decode, support SMPEG-1, MPEG-2, MPEG-4, H.263, H.264, AVS, VC-1, RV, VP6/VP8, Sorenson Spark, MVC
Video encoding formats: H.264, H.265, VP8, MVC (1080P)
Video Output: HDMI output: Ultra HD maximum support 4Kx2K (3840 * 2160), AV Output: PAL system and NTSC system
H.264, H.265 Frame rate: up to 60fps
Picture format: JPG, JPEG, BMP, GIF, PNG, JFIF formats picture browsing, support maximum resolution of 8176 * 8176
EBook Reader: Supports e-book formats TXT, LRC, PDF, Html, Htm, EPUB, etc.
Software expansion: Support Google market, support APK installation
There are currently 2172 users online. 0 members and 2172 guests.
