HPH Android TV BOX RK3288
Guest
Originally posted by no_spam_for_me View PostThat depends on what you want to do with it (no apps and so on!)
=> http://www.techsupportalert.com/free...d-useless.html
Originally posted by bloatman View PostI think some orders were placed thru the lower spec web page.
Originally posted by Burs View PostW-o-w. Just wow! Pure marketing. And pure stupidity. 5 years from now, we won't have on-board flash memory at all. Everything will be "out there", in the cloud. I'm sure many Android users won't be happy with that. But I hope for some workaround/hack. We'll see...
RK3288 Devices
- Overview BOX (LINK !)
Guest
Originally posted by no_spam_for_me View PostI don't test it jet, but seems to be a solution...
http://www.freaktab.com/showthread.p...l=1#post214014
I got a ROM coming for you folks!
Using the stock ROM I did my usual magic.
Gapps ate installed too
And maybe if you find a moment you can check the HDMI in -> out quality
(but of cause only if you have a moment)RK3288 Devices
I'm also curious about this post: http://www.freaktab.com/showthread.p...l=1#post214989
If RockChip doesn't have 2.0 working, then what is in this box?
And PCB redesign? Does this affect HPH?
Re: HPH Android TV BOX of RK3288 64gb 4gb ram $200
I'm one of the few believers that took a leap of faith and ordered a box (4G/32G) that still do not exist and we do not know if it will and when 😴
I believe that the box that Nagrace company sent to you has 4Gb of RAM, correct?
I now that you are busy doing your wonderful magic for all of us but we would love to know your impressions about the box, the 4Gb of RAM, the HDMI 2.0, etc.
Thanks a lot.
Originally posted by Evildropbear View PostI'm also curious about this post: http://www.freaktab.com/showthread.p...l=1#post214989
(and I think it affect ALL)RK3288 Devices
OK to answer a few questions.
1) My box has 2GB RAM and 8GB NAND.
2) I tested HDMI in. It does work and quality looks fine. I plugged in a tablet I have that outputs 1080P HDMI. However the only way to turn on HDMI IN so it shows on your TV is with a APP they supply called HDMI Test. Then to turn it off, you have to unplug HDMI in cable. I could find no way to turn it off.
So this is obviously work in progress and needs a setting or button on the Bottom Nav menu or something.
3) Mouse tends to lag and hang from time to time. Like the mouse is going to sleep. I have improved that quite a bit in my ROM I am making but it is still there especially right after boot up so you have to wait about 30 seconds for the system to calm down after a boot.
4) App partition is only 1GB so I will increase that in my ROM.
I have yet to test XBMC. A cannot do anything with 4K TV since I don't have one.
Box gives me a Antutu score of 40K BUT it is obvious more tuning from RK is needed in the SDK they provide to box makers as it doesn't "act" like it is twice the speed of the 3188.
Anything else you folks want me to report?
A good way to compare the quality via tablet (I think you see both at the same time at 1080p)...
"... unplug HDMI in cable ..." Or restart the boxRK3288 Devices
You see your tablet on the TV perfectly
Originally posted by taki View Posthi HPH___Tina
that is mini pci slot or sata connector
it is HI FI
thank you!
Tina
There are currently 1780 users online. 10 members and 1770 guests.
