Here's a lightly reworked ROM based on Cube's U65GT firmware of 20 June 2014. Updated to include instructions, missing drivers, flash tool etc.
ROM Download
If you have already downloaded the ROM without the instructions, drivers and flash tool then see post 7 for the missing files and download.
So what do you get
- English
- Root
- Removal of Chinese apps
- init.d support with busybox integration
- Option of CWM recovery built with rua1's MTK Droid Root Tool
- auto install feature:- if you create an autoinstall folder on your sdcard containing any default apks they will install on first boot. I tend to be sparing in this just loading my preferred file browser, terminal emulator and titanium backup.
I've included instructions within the download for flashing both the full ROM (required if you are changing from Cube's earlier firmware) or flashing just boot and system (ANDROID). Also included are both stock and CWM recovery.
Hope this of some use.
Brian
PS Lepi pointed out to me that its easy to boot into recovery as follows. First power off the U65GT, it vibrates when shut down completes. Press and hold power for about a second then press and hold vol+ until a menu displays (its small in white). Scroll through the menu options with vol+ and select with vol-
CWM zip fix for read only external sd card. Download and put onto the sdcard (internal or external), reboot to recovery and update. Corrected and tested 29 June 2014.
extsdcardfix.zip
In this post Lepi has uploaded a TWRP Recovery
Download
Screenshot
http://www.freak-tab.de/900superspor...LEPI_white.img
http://www.freak-tab.de/900superspor...LEPI_black.img
These are Lepi's updates of 3 July 2014 see post 57
