MK902 - KitKat 4.4 - SMIC717394 ---- 1080p and 720p ROMs
    Hi, whats the best 1080p versiob/link. Link me please. Thanks.
    Sent from my RM-821_eu_netherlands_315 using Tapatalk
      First page Is the 1080 p
        ill try to load the new version today or tomorrow.
        For all your computer problems...
        http://www.salvamipc.es
          Cool i got some back so ill test when ready,
            My older rom (still the smic jelly) is making the box a Little slow now. It's time for kk. Also very busy and having a loss in the family but now I got some time finally for other stuff again. The 1080p is stable?? Thnx
              Yup very even sound fix in it
              EDIT ----ok found wierd thing when i flashed the image no issues. when i flashed and changed the kernel boots few times and acted wierd. i reflashed both 1.7 and 1.8 got wierd boots and slow box got hot too so maybe a off chipset that wont take oc ???? just left with the image file that must be 1.6 right?
              Infin1ty- Sorry for your loss.
                Thanks buddy.
                One last question before i am going to flash. How does it work with older TV's? (with the a/v connected) does the sound etc. works proper? Cause i use the box on a Full HD screen (hdmi) and on a older CRT tv (a/v)
                Thanks.
                  How it the HDMI connected to the box - power?
                  Seems when i play the radio via xbmc it works fine when my TV is on, also on standby (lil stutters) but when i power off the TV the radio pauzes.. (like it feeds from the connection/power with the HDMI?)
                  Tried it 15 times and everytime it pauzes when i remove the power from my TV / turn it off.
                  When the box is connected via HDMI its some how connected to that HDMI which makes it pause.. never had this with the older rom from you smic.. how can this be fixed? I dont want to be forced to put my TV on when im playing radio.
                  (its connected HDMi for TV and for sound its digital connected to my reciever)
                  Also my antutu is pretty low compared to the other rom. I used the 1.7 kernel.
                    power down from hdmi been in every rom hmmmm, it takes in suspend when tv shut off, maybe Smic have setting different on this one.
                    did you flash image or the kernel selection as i had box running hot on the kernel selected 1.7 but ran faster better with the image file, and you will always get preformance hit in 1080p.
                    everything else running good.
                      On the old jelly rom it never powered off/paused when i shut down the TV. Can i fix this?
                      I flashed the kernel section. It does run a little hot, maybe ill reflash it with the included one.. (thats a 1.6??)
                        So you connect HDMI and the sounds mutes when you turn the TV off but the box remain on? I assume you connect optical then.
                        Its normal behavior, the SOC detects you are connecting hdmi and so when you are not connected anymore hdmi it cuts the sound, because it theory its not need it anymore since you just turn off the TV. Try the kernel bellow and let me know it its working.
                        The hdmi mute is already disabled in the kernel, the only think that could be is that when the SOC detects there is no longer HDMI connection, it assumes you are connecting DVI and cuts the sound.
                          The box is connected via HDMi for picture and optical for sound connected to my reciever. It plays fine - also when my TV is ''STAND-BY'' but when i turn it off - it pauses the player/radio. As in actually putting it to PAUSE. When i put my tv back on and set it on my HDMi 3 (the one where the box is connected) i can press play again and it starts back playing.
                          I'll try the kernel you posted.
                          Thanks.
                            ya i flashed with just the image think it 1.6 but didnt check, wont have box for week or so vacation time
                              with that 1.6 kernel its extremely poor antutu 17509 wow. It was almost 20k with the older rom.
                                Re: MK902 - KitKat 4.4 - SMIC717394 ---- 1080p and 720p ROMs
                                Ok. We were not discusing score here, i sent you this kernel to try the sound
